1978 - 1996 Big Bronco
Collapsing upper rad hose
Old Aug 6, 2003 | 10:26 AM
Copper93's Avatar
Copper93
This might be a silly question but which way does the water pump draw water, through the upper or lower radiator hose. My bronco is running fine but the upper rad hose collapses. I'm trying to figure out if it is my hose, thermostat, or a combo of both causing it. or if its just low on coolant.
Old Aug 6, 2003 | 11:23 AM
JBronco's Avatar
JBronco
Get a new hose, sounds like it's toast.
Old Aug 6, 2003 | 11:26 AM
lars915's Avatar
lars915
Water exits the engine through the upper hose, and reenters the engine through the lower hose. A collapsing upper hose may mean you have a bad radiator cap or plugged overflow system. When do you see the hose collapsed? If it's only when the engine is cold (like first thing in the morning), you probably have a bad radiator cap which doesn't allow coolant from the overflow tank to be drawn back into the engine or a plugged overflow hose between the radiator and the overflow tank.
Old Aug 6, 2003 | 11:55 AM
Copper93's Avatar
Copper93
Thanks, should of check that before I posted such a idiotic question on here. I just check and it was so clogged I couldn't even blow through it. I took a wire and ran it through the hose, cleaned out all the goop and that fixed the problem. I'll start thinking before I start posting on here.
Old Aug 6, 2003 | 04:59 PM
BillyBob69's Avatar
BillyBob69
No problem at all. Sometimes it takes another point of view to help us remember the basics.
Old Aug 6, 2003 | 05:47 PM
DW2455's Avatar
DW2455
Hey, don't beat yourself up to bad, stop shy of breaking your own bones, cuz we all have our BLONDE moments!! DW
Old Aug 6, 2003 | 06:21 PM
Black Ford XLT's Avatar
Black Ford XLT
My f-150 was collapsing,this is from heat wear( wearing out the inners)replaced it now all is well TR
J.Boyea518
Mar 19, 2016 11:45 PM
Island'r
Apr 6, 2014 10:49 AM
ruggles
21
Jun 23, 2010 05:39 AM
broncoboke
18
May 23, 2007 10:30 PM
88fordranger
Dec 12, 2005 07:32 PM
