Instrument light accessory plug
Old Oct 4, 2017 | 04:32 PM
ddepumpo's Avatar
ddepumpo
The truck is a 1974 F100 short bed, manual trans, original motor was a 302.
Does anyone know where the accessory plug C-789 (it might be C-709) can be found behind the instrument cluster? See page 5 of the wiring diagram (at grid E-50) below. In the notes, it is described as “behind instrument cluster for customer usage”. I can’t find it under the dash. It is supposed to be BL-R wires, so I assume it is connected to the dash lights. If so, I would like to use it for my tach light.
FWIW, I did find the yellow plug under the dash, and am using that as a switched power source for the tach. (I learned about this on the forum….thanks.) I currently have the tach light tapped into the fuse block, but it would be nice to find the accessory plug.
Old Oct 9, 2017 | 09:12 PM
ddepumpo's Avatar
ddepumpo
Anyone, anyone, Buehler ... just kidding. Has anyone else found this plug for accessory dash lights? Thanks.
Old Oct 9, 2017 | 09:33 PM
meangreen92's Avatar
meangreen92
Look for a light blue wire with a red stripe. There is for sure a place to plug in with a male spade terminal, at the radio connector. It's a two-wire connector with a yellow wire for switched power, and the blue/red wire for the radio dial light.
Old Oct 10, 2017 | 03:52 PM
ddepumpo's Avatar
ddepumpo
Thanks meangreen. I'll check it out.
Old Oct 10, 2017 | 05:10 PM
meangreen92
Oh wait, the three wire one is probably going to be up around behind your light and wiper switches. It's yellow on my truck. Sorry, kinda misread the OP...
jrotten67
Electrical Systems/Wiring
Jan 13, 2017 02:06 PM
ZachWiesehan
Dec 23, 2014 10:35 AM
yukonsly
Apr 22, 2007 12:24 AM
NateDog07
Apr 17, 2006 08:28 PM
nickmobile67
Feb 6, 2003 09:59 PM
