tachometer questions
Old Apr 16, 2006 | 09:03 AM
NateDog07's Avatar
NateDog07
i have a 91 f150, i'm wanting to install a tachometer in it... my question is, is there a plug somewhere under the dash or would i have to directly wire it into the distributor? if there is a plug in somewhere how can i recognize it?
Old Apr 16, 2006 | 09:32 PM
MRL123's Avatar
MRL123
No plug in for an aftermarket tach. You will have to follow the wiring instructions provided with the tach and tap into the neg. side of the coil plug along with a 12v for power, a ground and source for illumination.
Cheers!
Mike
Old Apr 17, 2006 | 08:28 PM
12secondstang's Avatar
12secondstang
Go to a local boneyard and buy a cluster with a tach. Usually from 20-40 bucks. It will plug right in. No need to chase, cut, splice wires.
