Sponsored by: Real Truck
Wiring led light strips
Old Dec 22, 2014 | 10:11 PM
ZachWiesehan's Avatar
ZachWiesehan
I was wanting to put some led light strips under my dash is there a way to dim them using the same dimmer that you use to dim you instrument cluster?
Old Dec 23, 2014 | 05:56 AM
Just Strokin's Avatar
Just Strokin
only if you can wire them into the dashlight circuit. You will need to find a wire some place under the dash for these lights. depending on your truck, the easiest place is the radio power plug. Later model 2011 and up, might not be that easy to access this plug and might not work.
Old Dec 23, 2014 | 10:35 AM
ZachWiesehan
I have a 2006 f250 and I had a friend that did his where they would dim down with his instrument panel. And where would that wire be locted?
ddepumpo
Oct 10, 2017 05:10 PM
Roy C
Aug 22, 2010 09:07 PM
yukonsly
Apr 22, 2007 12:24 AM
79 sb150
Electrical Systems/Wiring
Oct 23, 2005 06:15 PM
haviation
Sep 28, 2003 05:51 PM
