Busy busy
The store I go to had the brake fittings behind the counter in the back of store. They also have 3/16 NiCopp tubing.
AGS PN BLF-39C-5 - M10x1.0x 3/16 bubble flare
AGS PN BLF-48C-5 - M12x1.0x 3/16 bubble flare
I'm getting the booster and brackets ready for paint.
Thanks Steve!
This is where we are. I didn't see the dust until the picture, sorry.
The city is coming down on me, so I'll run brake lines to the existing PV for now. That'll at least give me time to collect some parts. Yes, it'll work. I did mine in 1995 and never changed the PV. We WILL do it on Staytons truck. Yes, I'll have to re-break another set of brake lines. I see it as more practice.
[IMG]https://cimg9.ibsrv.net/gimg/www.ford-trucks.com-vbulletin/2000x1124/80-
20171007_085357_resized_9fd0f6ece243d82f2587555d81 11f25e70f35afe.jpg[/IMG]
Thanks Steve!
What I got doesn't look like the AutoZone pic.
AutoZone PN 54-73112
Back to the parts store I go.....
Thanks Steve!
My dual diaphragm booster (donor originally came out of a '75 F350. I exchanged the core for a newly rebuilt booster), didn't have an adjustable input rod. It had a long, fixed length rod. I didn't know until sometime after-the-fact that the same basic booster was available in the '68-'72 F350 Bumpsides.
The main difference on them (compared to the Dentside version) is that they have an adjustable length input rod (input rod code FT8).
"FT8"code stamped on the input rod, where the adjustable eyelet screws in. This was on the rebuilt, dual diaphragm, F350, Bumpside booster I installed in my friend's '72 F100.
If you haven't already installed the booster, it isn't too late to take it back where you got it from and see if you can work with the parts counter person to get this version of that booster.
A rebuilt booster designed for the adjustable input rod will not come with the eyelet --I guess they assume you're swapping parts for parts and that you would just reuse the original eyelet off the booster being removed. If you didn't have the booster to start with, you'll have to come up with an eyelet from a donor or, machine/make your own.
When this happens, a ground path is completed through the body of the valve, through the chassis and back to the brake warning light on the dash. At that point, the warning light is lit up.
The '68-'72 F250/F350 trucks with factory front discs had the same style of pressure differential valve. The only major difference being that they also had a stand-alone metering valve to the front discs. The metering valve was mounted on the front crossmember, separate from the PDV.
Before 1973 though, no Ford truck came with a proportioning valve function. In '73, for an F100 - F350 2WD truck, the brake valves were integrated with 3 functions: Metering to the front discs, Pressure differential sensing between the front and rear brake circuits and a Proportioning function to the rear drums.
Example of the inner functions of a Kelsey-Hayes disc/drum brake valve for a 2WD truck under 6900# GVW.
Dentside 4x4s didn't get front discs until 1976. Prior to '76, the '73-'75 4x4s had a PDV like the Bumpsides.
I used DOT 5.0 silicone brake on the highboy and it works great! You can make an absolute mess with brake fluid sprayed every where and not clean it up for days and it won't harm your paint at all. Ask me how I know.
Silicone brake fluid will not harm buna-n, neoprene, viton or kalrez seal material. Its what Harley Davidson uses in their bikes. You do not want to mix glycol based brake fluid with silicone brake fluid. You also do not want to use silicone brake fluid in a vehicle that has anti-lock brakes, silicone brake fliud is too viscous.
iron MC. The '95 Explorer MC looks a little too new for me. I also like this booster in that the cast iron MC won't stick out so far.
Be very sure NOT to mix DOT 3 with it. Read the SDS for both and manufactures direction of use. I was just talking about this very thing with a marine buddy of mine that serviced the motor pool. I'm not sure if it this axact case, but the 2 fluid they used caught fire when heat was added.
I went to that auto parts store "where they wear the yellow hat" and they couldn't hook me up. (I visited 3 other auto box stores) However, Prior Brake Rebuilders is here in dallas. I have their number so I can call them directly.
It's not Ultra quality, but it was good practice and mucho cussing. It'll do for now. I lost the banjo bolts and there were none to found at the box stores. Stayton will pick them up this morning, install brake lines to calipers and start a gravity bleed until I get home from work.
