Sponsored by: Auxito
Trans fluid?
Old Sep 15, 2017 | 04:01 PM
69ford99's Avatar
69ford99
Trans fluid?
I have a 2000 expedition with the 4r100. Certified transmission put a remanufactured trans in it last year. I added a trans cooler today and was going to add some fluid but wasnt sure if I needed to add mercon or mercon V. The dipstick says mercon, so I called certified transmission and they said the put peak full synthetic multi vehicle atf in it and just to use that. I looked up the peak full synthetic and it said not for use where mercon V is required. Guess im stuck using that now?
Old Sep 15, 2017 | 04:05 PM
steve(ill)'s Avatar
steve(ill)
MERCON is the old spec and normally not available in stores. MERCON V is the new spec and almost ALL vehicles upgrade to the new spec. "GENERIC" fluids that do not meet the MERCON V spec are not recommended.
Old Sep 15, 2017 | 04:11 PM
steve(ill)'s Avatar
steve(ill)
looking up the PEAK fluid, it appears it is for the Newer FORD 6 speed transmissions and GM Dextron IV vehicles.. Not saying it wont work in the older FORD trans, but not recommended.
Old Sep 15, 2017 | 04:30 PM
69ford99's Avatar
69ford99
They installed a new torque converter and flushed the trans cooler when they put it in. Guess time will tell.
Old Sep 15, 2017 | 05:02 PM
projectSHO89's Avatar
projectSHO89
Does NOT meet Ford's Mercon V specification.
Old Sep 15, 2017 | 05:21 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Maybe they know what they are doing. But I would NEVER put that fluid in a 4R100. The only Ford spec that it lists is MERCON SP. MERCON SP will kill a 4R100. Source: PEAK ATF Spec Sheet.
Old Sep 15, 2017 | 06:16 PM
steve(ill)'s Avatar
steve(ill)
MERCON® SP Automatic Transmission Fluid
Motorcraft® MERCON® SP is a premium-quality fluid recommended by Ford Motor Company specifically for use in Ford, Lincoln and Mercury vehicles that require MERCON® SP type fluid. This product also provides excellent performance in electronically controlled automatic transmissions. Check Owner’s Guide or Workshop Manual for correct applications
Motorcraft® MERCON® SP is manufactured with premium base oils and specially designed performance additives, which provide excellent shifting characteristics at high and low ambient temperatures, excellent thermal and oxidation resistance. It provides wear protection and inhibits the formation of gum, sludge, lacquer and foam. It also provides protection against rust and corrosion. MERCON® SP is friction modified for smooth transmission operation while guarding against transmission shudder
Do not use in transmissions requiring MERCON® V, MERCON® LV, Continously Variable Chain Type Transmission Fluid, Motorcraft® Premium Automatic Transmission Fluid, FNR5 Automatic Transmission Fluid, or Type F Fluid
Refer to the Motorcraft® MERCON® SP product data sheet at the link below for additional information. For MSDS information call 1-800-448-2063
Old Sep 15, 2017 | 08:39 PM
69ford99's Avatar
69ford99
So should I take it in somewhere and get the trans flushed out and put mercon V in?
Old Sep 15, 2017 | 09:15 PM
Mark Kovalsky
I would. Or if you want to do it yourself: https://www.ford-trucks.com/articles...-transmission/
Old Sep 17, 2017 | 08:49 PM
Mickey Bitsko's Avatar
Mickey Bitsko
What did the remanufacturer put it when they put it in the expedition?
Is might be still under warranty.
I bought a certified 4r70w last fall, they put peak full synthetic, about 20k miles no problem.
Old Sep 18, 2017 | 02:05 PM
69ford99's Avatar
69ford99
I called certified transmission and asked about the peak synthetic and it not being compatible with mercon or mercon V applications. They said the 4r100 was on their list of approved applications. When I looked up the specs again I noticed the application list from 2013 didnt list mercon or mercon V but the list from 2016 lists Mercon but specifically says not for mercon V.
Old Sep 18, 2017 | 04:19 PM
steve(ill)'s Avatar
steve(ill)
MERCON is NOT available.. The "NEW" is Mercon V.... If MERCON V will not work, then either will MERCON.......... other versions of FORD spec fluid are MERCON LV and SP... they are NOT MERCON V replacements.
MauleOne
Feb 9, 2012 10:08 AM
Rotterdam24
Aug 27, 2010 03:02 PM
crazer42
16
Apr 6, 2009 09:34 PM
96powerstroke
Jan 16, 2006 05:32 AM
wheelieboygsxr
Aug 5, 2003 10:19 PM
