trans fluid
Old Apr 5, 2009 | 06:39 PM
crazer42's Avatar
crazer42
trans fluid
im ready to have a trans flush but what is better synthetic or conventional fluid? how much more will i pay?
Old Apr 5, 2009 | 07:09 PM
Izzy351's Avatar
Izzy351
I prefer syn fluids all the way around, but that's me. I put in Mobil1 Full Syn Mercon V, and it ran me about $110. Schaeffer's Syn ATF is about the same money.
Old Apr 5, 2009 | 07:42 PM
flamebuster's Avatar
flamebuster
I belive mercon v is a synthetic they don't make mercon anymore.
Old Apr 5, 2009 | 08:11 PM
rebelchevy02's Avatar
rebelchevy02
I run royal purple, its about $12 a quart.
Old Apr 5, 2009 | 09:21 PM
Izzy351's Avatar
Izzy351
Mercon V can be dino too.
Old Apr 5, 2009 | 09:46 PM
big poppa's Avatar
big poppa
Mark mentioned this also Joe, good point. How the heck do you know on the bottle if its full syn???? Also, Mobil syn is hard to find around here, I too got to do a full flush??
Old Apr 5, 2009 | 10:23 PM
Izzy351's Avatar
Izzy351
It should be fairly obvious. First, it will be more expensive than dino, second, if it's syn, the company's marketing dept. should make it obvious on the bottle.
EDIT: Here's another option for you:
http://www.valvoline.com/pages/produ...sp?product=117
Old Apr 5, 2009 | 10:32 PM
rebelchevy02
If you have a little time amazon.com has it too for a little under 140 a case, with free shipping.
Amazon.com: Royal Purple Max ATF Automatic Transmission Fluid, Quart Bottle, Pack of 12: Automotive
Old Apr 5, 2009 | 10:37 PM
big poppa's Avatar
big poppa
I'm assuming Mercon V AND Mercon on the same Motorcraft gallon jug means Syn, thats what I got, a leftover anyways, thanks Joe.
Old Apr 5, 2009 | 10:45 PM
Izzy351's Avatar
Izzy351
Only if it says "Synthetic" or "Synthetic Blend" on it...
Old Apr 6, 2009 | 06:50 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Why would you assume that? I don't follow. If it doesn't say synthetic it's a bad assumption to think that it is synthetic.
Old Apr 6, 2009 | 08:21 AM
brian42's Avatar
brian42
Veteran: Navy
If it says "Synthetic" on the bottle, then it's synthetic. If it doesn't say that it's synthetic, then it's all dino.
Mercon V is the new rating that Ford has for it's tranny fluid requirements. I don't know what the difference is between Mercon and Mercon V (amount/type of additives?), but initially the big stink was that if you were supposed to use Mercon rated fluid, you should in no way ever use Mercon V. A while back Ford came out and said okay now you can use Mercon V (I don't remember the TSB number off hand). I think this was due to the fact that Ford was phasing out the Mercon rating and going with the Mercon V rating. There's still some old school thought out there that we can't use Mercon V in our rigs because it was such a hullaballoo. As long as it says that it's Mercon V rated, then you can use it (the Mercon rating has been phased out, although you may be able to find it on some old stuff).
If you can afford it, synthetic is always better than dino.
Just my .02
Old Apr 6, 2009 | 08:27 AM
big poppa's Avatar
big poppa
Thanks for the tip.
Got yaa..thanks Joe
I thought everybody was saying Mercon V was synthethic? and just plain ole Mercon was you non-syn. A Ford dealer up the road that did my CPS recall said the same thing, Mercon V is syn?? Man, I thought I had this down by now, this topic has been beat to death.. Thanks Mark as always Just seen your post Brian, thanks for the clarification, got it now..
Old Apr 6, 2009 | 10:27 AM
cjcocn's Avatar
cjcocn
Just my .02
Rep for that post!
I was only going by the owners manual and would have stayed away from Mercon V had I not read your post. You probably saved me a ton of running around trying to find some old stock!
Old Apr 6, 2009 | 10:53 AM
white Buffalo's Avatar
white Buffalo
Just Some additional info:
The 4R100 calls for a MERCON ATF spec Fluid. MERCON is no longer being supplied, MERCON V can now be used in vehicles that require either MERCON® V or MERCON® type fluid.
You can also use:
1. MERCON® V Automatic Transmission and Power Steering Fluid
2. Motorcraft's Synthetic Blend MERCON® V Automatic Transmission
Synthetic Blend MERCON® V Automatic Transmission and Power Steering Fluid
If you tow or race I would go with a full synthetic since it can handle the higher temps better and last longer.
3. Schaeffer's 204SAT Synthetic Transmission fluid - what BTS uses in all their transmissions
Schaeffer's ALL-Trans Supreme Transmission Fluid for Dexron III and Mercon fluids
or
4. Amsoil Synthetic Automatic Transmission Fluid
AMSOIL Synthetic Automatic and Manual Transmission Fluid.
5. Amsoil Torque-Drive™ Synthetic Automatic Transmission Fluid (ATD) - very expensive $45 a gallon retail IIRC
AMSOIL Torque Drive
IMO opinion paying $50 a gallon for Amsoil, Royal Purple, etc.... is not worth the extra $ for no performance gain. Compare the technical data sheets of the fluids and decide for yourself. You can easily save @ $20 a gallon. I use Schaeffer's 204SAT Synthetic Transmission fluid like BTS does in all their 4R100's. runs @ $115 for 5 gallons.
