2006 expedition transmission cooling lines
Has anyone with an expedition replaced the transmission cooling lines? Mine are rusted I know where the two lines attach to the transmission they connect with a 16mm nut. I am having a hard time getting at the nut to remove it. Any suggestions? I guess if I can't get at it with the line attached I can always cut the line and use a socket but I am not sure that will help with the install. I've seen photos of the F150 and there is more clearance to reach the connections. I'll post some pictures tomorrow. Thanks
T-wood
02-27-2018 07:28 AM
dan_s_johnson
1997-2006 Expedition & Navigator
08-05-2015 04:16 PM
