C700 Engine Transmission Swap
Taking suggestions on upgrading my 73 C700 Want to put a updated version power plant in it but have the dilemma of the E-Brake And want it to be a automatic I have a Low Mile complete F350 EFI 460 Engine with automatic but the E- brake has me puzzled. any suggestions
Welcome to FTE.
The E-brake.... Does the truck have a transmission mounted E brake at the output shaft, and your substitute transmission doesn't?
Your new trans is probably an E4OD. I am pretty sure there is a model of that trans with the e-brake incorporated, from on of the F or E 350 models.
Your EFI motor and trans will need the engine controller to run, along with the wiring harness.
What are you going to do with the truck?
Also, potential deal killer question: How are your brakes? Drums are not available for these, but all other parts are.
The E40D does not have one on it. The current Unit is a (Stick) with a trans mounted E-brake.
I have all the wiring harness and Controllers for the Engine and transmission.
Usage: Well it is either going to be a flat bed Drag Car Carrier or a Shop truck not sure exactly but it will see some freeway service.
Brakes: Hmmm well yet to be seen. I know it need work so well see.
Post 10 has a pic, you can find out the model in the text. Sorry, in a hurry...
E4OD blew up. Other options? MT or AT - Diesel Forum - TheDieselStop.com
woobiemonster
02-26-2016 12:45 PM
ziggy857
07-05-2010 09:07 AM
Rokcrln
07-04-2009 10:36 AM
