Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
C700 Engine Transmission Swap
Old 08-23-2017, 01:01 PM
Poniak's Avatar
Poniak
Poniak is offline
Taking suggestions on upgrading my 73 C700 Want to put a updated version power plant in it but have the dilemma of the E-Brake And want it to be a automatic I have a Low Mile complete F350 EFI 460 Engine with automatic but the E- brake has me puzzled. any suggestions
Old 08-23-2017, 01:08 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,722 Likes on 1,406 Posts
Welcome to FTE.
The E-brake.... Does the truck have a transmission mounted E brake at the output shaft, and your substitute transmission doesn't?
Your new trans is probably an E4OD. I am pretty sure there is a model of that trans with the e-brake incorporated, from on of the F or E 350 models.
Your EFI motor and trans will need the engine controller to run, along with the wiring harness.
What are you going to do with the truck?
Also, potential deal killer question: How are your brakes? Drums are not available for these, but all other parts are.
Old 08-23-2017, 01:37 PM
Poniak's Avatar
Poniak
Poniak is offline
The E40D does not have one on it. The current Unit is a (Stick) with a trans mounted E-brake.
I have all the wiring harness and Controllers for the Engine and transmission.
Usage: Well it is either going to be a flat bed Drag Car Carrier or a Shop truck not sure exactly but it will see some freeway service.
Brakes: Hmmm well yet to be seen. I know it need work so well see.
Old 08-23-2017, 02:27 PM
85e150's Avatar
85e150
Post 10 has a pic, you can find out the model in the text. Sorry, in a hurry...
E4OD blew up. Other options? MT or AT - Diesel Forum - TheDieselStop.com
Old 08-23-2017, 02:44 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is online now
Received 1,641 Likes on 1,102 Posts
The transmission mounted E-Brake usually mounts to a 4x4 transmission. If the E4OD you have is from a 4x4 the E-Brake may just bolt up to it. If it isn't a 4x4 trans it needs to be rebuilt to turn it into one.
Old 08-23-2017, 02:49 PM
Poniak's Avatar
Poniak
Poniak is offline
Awww got it. Good to know Thanks.
Old 08-23-2017, 07:48 PM
Poniak's Avatar
Poniak
Poniak is offline
Thought, Using the 361 FE and the C-6 Round bolt pattern with a Mounted E-Brake in the trans? Injecting the 361 ?
Old 08-23-2017, 11:10 PM
85e150's Avatar
85e150
Hard to make more power out of the 361 without adding compression and cam. Injection will clean it up, but not much more power.
C6 with a attached E-brake? Seems like the E4OD set up would be easier to find.
Old 08-24-2017, 09:36 AM
Poniak's Avatar
Poniak
Poniak is offline
I think you right but my other problem seems that the E40D is missing the VSS is there a way around that?
Old 08-24-2017, 09:41 AM
Mark Kovalsky
Yes, there is. You can mount a tone ring on the driveshaft. Make a mount for the VSS to read that ring.
Old 08-24-2017, 11:04 AM
Poniak's Avatar
Poniak
Poniak is offline
So simple Thanks So Much..
woobiemonster
02-26-2016 12:45 PM
ziggy857
07-09-2010 10:16 PM
ziggy857
07-05-2010 09:07 AM
Rokcrln
07-04-2009 10:36 AM
Quick Reply: C700 Engine Transmission Swap
