2015 F550
Old Aug 17, 2017 | 03:32 PM
tjc transport's Avatar
tjc transport
i ain't rite
2015 F550
the service truck threw a CEL, and i pulled oxygen sensor performance bank one sensor one code.
that would be driver side sensor between the manifold and cat, rite?
don't want to change the wrong one
Old Aug 17, 2017 | 03:42 PM
djousma's Avatar
djousma
Is this a gasser or a diesel? No oxygen sensors on a diesel as far as I know, but then again I didn't sleep in a Holiday inn last night either.
Smart ace aside, what was the code you pulled?
Old Aug 17, 2017 | 03:58 PM
tjc transport
i ain't rite
don't remember the code. and yes diesels have 4 o2 sensors, 2 before the cats and 2 after the cats.
Old Aug 17, 2017 | 06:18 PM
djousma's Avatar
djousma
Ok, I guess I'm confused. Not aware of any catalytic converters on these diesel engines either. Here is what I know to be on the exhaust:
http://http://www.powerstrokehub.com...emissions.html
Is it possible you got a code definition for a gasser instead of diesel?
Old Aug 17, 2017 | 06:48 PM
EO2SeaBee's Avatar
EO2SeaBee
The DOC (Diesel oxidation catalyst) is for all intents and purposes a catalytic converter. Without crawling under my truck, I won't swear to the presence or absence of any O2 sensors, but post turbo, I only recall disconnecting 4 EGT sensors, a DEF injector and a NOx sensor to remove the exhaust system.
Old Aug 17, 2017 | 06:51 PM
tjc transport
i ain't rite
if there are no cats, there is something in the exhaust between the turbo and muffler.
i assumed it was a cat.
and i can see the confusion.you are correct, i described my 6.2 engine.
i am going on what was done to this truck when it was 3 months old. the engine shut off and the dealer said it was one of the o2 sensors. only that time they replaced all 4 of them instead of testing each one because it was a friday afternoon on a holiday weekend.
they replaced 4 sensors and we had no other problems with the truck until the CEL came on yesterday afternoon.
Old Aug 17, 2017 | 06:53 PM
djousma's Avatar
djousma
I bet they replaced the 4 EGT sensors at that time. If you can get the code, we can try to help!
Old Aug 17, 2017 | 06:59 PM
djousma's Avatar
djousma
Forgot to add, that if one of the egt sensors is going bad, the code usually identifies which one. Those sensors can be had for about $40 online. Pretty easy to replace assuming it hasnt siezed the threads. A lot of penetrating oil and a good soaking usually helps.
EDIT:. Rereading your original post, maybe the code you got is for egt11, the first one post turbo.
Old Aug 17, 2017 | 07:11 PM
tjc transport
i ain't rite
checked scanner, i did not clear codes .
P164A
P20B9
P20BA
P2A00 oxygen sensor circuit range / performance, bank 1 sensor 1
Old Aug 17, 2017 | 07:48 PM
djousma's Avatar
djousma
P164A-nox sensor
P20B9-reductant heater 'a' control circuit open
P20BA-reductant heater 'a' control performance
For p164a abd p2a00 I do find references to nox sensor here:
https://www.ford-trucks.com/forums/1143614-tsb
the others I bolded above. Related to def system?
Old Aug 18, 2017 | 05:07 AM
Just Strokin's Avatar
Just Strokin
Look at the 6.7 goffee table book and see if it shows the O2.
Coffee Table Books
Also might check the OBDII for your year truck and see what it says.
https://www.motorcraftservice.com/freeresources/obd
Old Aug 19, 2017 | 06:14 PM
tjc transport
i ain't rite
we never got to the F550 yesterday or today as we spent both days working on the 05 Kenworth.
CMOS
2009 - 2014 F150
May 5, 2020 07:52 PM
rangergolfer
1983 - 2012 Ranger & B-Series
Dec 16, 2011 02:36 PM
eigenvector
Nov 15, 2009 11:24 AM
84f250460
1997 - 2003 F150
Dec 2, 2006 10:10 PM
Blue'87GT
1978 - 1996 Big Bronco
24
Nov 20, 2004 10:30 PM
