just fixed p0455 problem now i got a new code : p0136 O2 sensor malfunction( bank1 sensor2) where is this located and what does it roughly look like?
thanks in advance......
What did you do to clear the p0455 code? If you didn't have the 0136 code before you cleared the 0455 it's possible that it was caused by fixing the 0455.
If you have an OBDII use it to clear the p0136 code and see if it comes back or not. Otherwise go to AutoZone to ask them to clear it for free.
I once changed the MAF on an SUV and it caused an O2 sensor malfunction code but I cleared the code and it never came back.
Bank 1 Sensor 2 is the O2 sensor after the CAT on the passenger side.
