OBD2 code p0136
Old Dec 16, 2011 | 12:03 PM
rangergolfer's Avatar
rangergolfer
OBD2 code p0136
I have a y2k ranger 3.0 engine and i'm pulling a p0136 error code. From what I can tell that is oxygen sensor 2 on bank 1. The truck has 85k mi so it's probably time to change it but is there an easy way to check it out? Thanks.
Old Dec 16, 2011 | 02:36 PM
pawpaw's Avatar
pawpaw
P0136 is for a bank-1 down stream/after cat converter O2 sensor circuit failure. If you don't have any test equipt, you could swap it for the bank-2 after cat O2 sensor & see if the code follows the sensor. If it does, suspect the O2 sensor, if not, suspect a wiring or electrical connector problem on the bank-1 side.
Sancho
Modular V10 (6.8l)
Jul 25, 2016 09:31 AM
poseidon
1997 - 2003 F150
May 29, 2010 04:11 PM
MikeRizz
Mar 24, 2010 09:56 AM
jim milewski
Nov 1, 2009 09:16 AM
tosterbe
Jan 7, 2003 10:46 AM
