Help with P0430 code: driver's side CAT..
Old Aug 1, 2019 | 07:28 AM
CMOS's Avatar
CMOS
Howdy Guys,
Been fighting a P0430 for a few weeks now - Driver's side catalytic converter bank. After reading several post on this and other sites I troubleshooted in the following manner, from the lowest cost up:
1. replace all spark plugs. Clear code. Came back after a couple days.
2. Replace downstream O2 sensor. Clear code. Cam back after a couple days.
3. Replace upstream O2 sensor. Clear code. Came back after a coupe days.
It's been 3 weeks since the last sensor was replaced. Odd thing is that the CEL will come on and off over a period of several days, then come back on days later.
I would like to NOT have to replace that CAT right now due to finances. My question at this point is - Is there any type of TSB out there that widens the spec for this CAT bank sensor pair?
Thoughts? Is the CAT the only thing left that I have to do?
Thanks for any help.
CMOS
Old Aug 1, 2019 | 11:07 AM
Beechkid's Avatar
Beechkid
If the cat is partially clogged, there is a possible option......you can pull the cat and with a bucket wash it (internally) with soap/water hoping to clear it out...….you can also try a cat cleaning product (pour into fuel tank type) and see it that might help a little. If you can clean it out, assuming the internals aren't falling apart, it should be ok.
Old Aug 1, 2019 | 12:15 PM
ibdagriz's Avatar
ibdagriz
If it's the downstream sensor the folks on a Dodge charger forum have had luck by using an anti fouler which moves the sensor out of the exhaust stream and keeps the sensor from throwing a code.
My hemi charger was throwing the same code and this method has kept it from throwing the code ever since I installed the set up on my car.
http://www.lxforums.com/board/showthread.php?t=37086
Griz
Old Aug 1, 2019 | 07:38 PM
projectSHO89's Avatar
projectSHO89
All of my old OBDII Fords have seemed to end up with anti-foulers on the downstream O2 sensors for some reason....
As long as the converter internals haven't broken up or melted, moving the downstream sensor out of the exhaust stream has done the trick.
Old Aug 2, 2019 | 05:59 AM
tseekins's Avatar
tseekins
Veteran: Coast Guard
To the OP,
Is the truck running any differently? Have you had any type of an induction service performed such as a walnut blast?
Old Aug 2, 2019 | 03:28 PM
CMOS's Avatar
CMOS
Originally Posted by tseekins
To the OP,
Truck runs like a top. No driveability issues at all.
No modifications at all, with the exception of a boost side Catch Can.
CMOS
Old Aug 7, 2019 | 08:03 PM
bwep's Avatar
bwep
I went down the same road you did. I managed to get 6 months without the check engine light after new plugs, boots both o2 sensors. Once it returned I cleared it a few times but kept coming back.I ended up purchasing a Walker converter from Rock Auto . Price was around 150.00 and install was not to hard. My truck( ecoboost ) had 130,000 on it and now at 136,000 so far so good.
Old Aug 8, 2019 | 12:09 PM
CMOS's Avatar
CMOS
That's good to know. I may end up dong that. Was the Walker CAT a direct bolt-on, meaning did it fit well?
I need to do some more research about whether the CAT can be "cleaned". I'd like to be able to hear from someone that did "clean" the CAT and got good results.
CMOS
Old Aug 8, 2019 | 04:21 PM
bwep's Avatar
bwep
CMOS
Yes it was a direct fit. Two bolts on the turbo.I have a Milwaukee 1/2 impact gun. Couple of extensions and a universal came right off. The band clamp I ended up cutting the bolt and replacing. You already have dealt with the 2 O2 sensors, so that's about it.
Old Mar 12, 2020 | 04:32 PM
CMOS's Avatar
CMOS
@bwep
How's that new CAT working? Still no CEL?
CMOS
Old Mar 17, 2020 | 10:50 AM
bwep's Avatar
bwep
I drove an additional 6,000 miles after the replacement converter with no return of check engine. Truck was traded in (136,000) running good in November. Have a 2019 with 5.0 now.
Old Apr 21, 2020 | 12:44 PM
CMOS's Avatar
CMOS
Curious as to why the new 5.0 vs. another EB?
CMOS
Old May 5, 2020 | 07:52 PM
bwep's Avatar
bwep
CMOS
The new truck was a heavily discounted special , just happened to have the 5.0.
poseidon
1997 - 2003 F150
May 29, 2010 04:11 PM
tinman52
Oct 30, 2009 08:21 PM
kawirider00
Apr 19, 2007 09:51 PM
71ranchero500
Nov 13, 2005 07:41 AM
Blue'87GT
1978 - 1996 Big Bronco
24
Nov 20, 2004 10:30 PM
