Thanks Guys! I have been reading about procedures to flush the transmission, although they very quite a bit, I was wondering what method you all recommended ?
Thanks for all your help guys!!! What an awesome community!
I have been doing tons of research on this topic. It looks like lots of folks use Valvoline Max Life ATF. Do you guys have an opinions on this product ? It seems to be more cost effective than the Amsoil products. Considering im going to be flushing the system, I wonder if this product would be more cost effective.
On a side note, since im doing all of this, I orderd the 2008 Pan and the improved paper filter.
I'm about to do this on the 5R110 Torqueshift and was wondering is the drain plug in the pan has a crush washer like the engine oil drain plug.
I was at the dealer today picking up FT-145 filter and seal - their diagrams showed no such part. No o-ring or crush washer on the transmission drain plug.
Should I just use some teflon tape on the plug when I put it back in?
