Sponsored by: Real Truck
2003 6.0 torqshift fluid change
Old Jun 1, 2011 | 03:52 PM
cyclone3565's Avatar
cyclone3565
Well, I just bought a 2003 6.0 with 161K on it and it runs great. The previous owner told me that he changed the transmission fluid in the fall of last year and I must say it shifts absolutely perfect and the fluid looks and smell good, however, the external filter cap does not look like it has been touched. I am going to pick one up and look at the external filter tonight or tomorrow night.
Being that it shifts so perfectly, should I worry about changing the fluid and internal filter or just see what the external looks like (for all I know it could be factory), and swap it out.
Old Jun 1, 2011 | 04:19 PM
jc8825's Avatar
jc8825
If the fluid looks good, you should be fine. If the filter is bad, your fluid will degrade quickly and you will notice it when you check. You could go ahead and change the spin on filter, but I would only change that at this point.
Old Jun 1, 2011 | 04:25 PM
cyclone3565
That is kind of what I was thinking as well. The fluid looks great, the trucks shifts better than my last one (04), but like I said the canister is suspect, so I figured that might need attention only.
Old Jun 1, 2011 | 04:26 PM
5.4f250sd's Avatar
5.4f250sd
I guess we all have our opinions, but I bought both the external (toilet paper) and internal(screen) filter after the purchase of my truck. I also changed all the fluid. The torque shift fluid is supposed to be changed every 30000 miles. If it were me I would change all the filters and fluid that way you know where you are at and will make sure your good for miles to come!
Old Jun 1, 2011 | 04:33 PM
cyclone3565
That is a very valid point. the dealer wants $260.00 to do it, that was my only hesitation, and considering how nice it shifts...............
Old Jun 1, 2011 | 07:58 PM
sandmanf250's Avatar
sandmanf250
fluid change
every 6 months 1 new roll of t-p and 8 quarts of s-p .200,098 and no problems.
Old Jun 1, 2011 | 08:29 PM
cyclone3565
I will PM as well. Do you loose 8 quarts of fluid changing just the exterior TP filter?
Old Jun 1, 2011 | 09:00 PM
sandmanf250
8 qts
thats what comes out without droping the pan which only filters birds and big rocks.i change the t-p and 8 qts every 6 months, no problems @200,000 miles
Old Jun 1, 2011 | 09:01 PM
cyclone3565
You mean by removing the TP filter and the drain plug in the bottom of the pan?
Old Jun 1, 2011 | 09:06 PM
sandmanf250
draining
yep 8qts is half oil change. works for me.
Old Jun 1, 2011 | 09:26 PM
cyclone3565
thank you so much. gives me something to do this weekend. Rotate tires (always do it myself) grease slip joint on drive shaft and tranny.
Thanks again
Old Jun 1, 2011 | 11:24 PM
5.4f250sd's Avatar
5.4f250sd
I do the 8 qts every 15000 and a tp at 30000 and when I got the truck I also did the pan filter for the hell of it!
Phillipspd
Feb 24, 2017 10:05 PM
Chevota_72
Jul 15, 2016 08:32 PM
silverbullet6oh
May 1, 2016 01:59 PM
qman
Jul 1, 2015 05:26 PM
Zip
Jun 16, 2014 10:57 PM
