Ford 6R80 6 Speed Transmission Fluid and Filter Change
Old Aug 24, 2014 | 07:39 PM
makuloco2000's Avatar
makuloco2000
I actually got allot of request for this video to be done and I think it turned out well. As it turned out many are unsure of the whole filter setup inside. I go over the fluid and filter change with all my tips along the way. The setup is the same for any 6R60 or 6R80 transmission found in many Ford Vehicles but this one is demonstrated on a F150.
Fluid Fill & Adjustment
Old Aug 24, 2014 | 08:35 PM
meborder's Avatar
meborder
Linked to Stickies.
Thanks for posting!
Old Aug 24, 2014 | 10:46 PM
bigdaddyII's Avatar
bigdaddyII
Thank you for posting these videos. It helps a lot to see what you will encounter before going in blind.
Old Sep 7, 2014 | 09:18 AM
09Larriat's Avatar
09Larriat
Looks easy enough. About 120,000 Kim's on her now. Maybe next weekend.
Thanks
Old Oct 26, 2014 | 03:44 PM
makuloco2000
Agreed, if anything it provides that for sure.
Old Oct 27, 2014 | 08:09 PM
Buck268's Avatar
Buck268
Thanks! Bookmarking.
EDIT: Actually, a question. The dipstick on my '11 has an "A" and "B" crosshatch area- any info on this? Assuming its COLD and HOT but???
Old Nov 5, 2014 | 11:03 PM
makuloco2000
Yes A is cold and B is full hot.
Old Apr 13, 2016 | 04:41 PM
cghstrojan08's Avatar
cghstrojan08
Needing to do this on my '13. The book calls for 13.1 quarts capacity. Sounds like from your video I only need maybe 7?
Old Apr 13, 2016 | 06:45 PM
eriebasin's Avatar
eriebasin
I just recently had this service done at the dealer; and they botched it. It was a monstrous ordeal; however they made it right.
here is a link to the thread:
https://www.ford-trucks.com/forums/1...re-help-3.html
Nonetheless, from what I learned, the dealer only put in 7 quarts when they first dropped the pan and changed the fluid. Then, after the torque converter was replaced and they dropped the pan, it took ten quarts. The capacity is for a total of 13.1; when I questioned them they said the remaining 3 quarts was in the transmission itself. Just to please me, they put me underneath one last time before i hit the road to show me the level was full.
Please let me know how the service goes.
Cheers!
Old Apr 13, 2016 | 07:27 PM
fastback89's Avatar
fastback89
This is a great video and in my opinion important to prevent future issues, I guess some people don't agree with filter changes and insist leaving the oem filter in there for the life of the truck. 36 dollars for the filter and 7 quarts of fluid seems like cheap insurance??
Old Apr 13, 2016 | 08:17 PM
eriebasin's Avatar
eriebasin
Agreed! Although due to my dealer's screw-up, I ended up with two weeks of difficulties and a new torque converter; but, with it all behind me, this was still a good decision to have done.
Old Jan 10, 2018 | 07:59 AM
CMOS's Avatar
CMOS
Pardon the ignorance but if I don't have that fluid fill fitting that he had in the video, can I fill through the dipstick tube?
CMOS
Old Jan 10, 2018 | 09:12 AM
Tom's Avatar
Tom
CMOS
Unfortunately you don't have a dipstick tube, the 6R80 has always needed to be filled from underneath.
Old Jan 10, 2018 | 09:14 AM
CMOS's Avatar
CMOS
Well, that would be a problem, wouldn't it.
I see that I can buy a small pump to fit on the top of the quart ATF bottles. That will work.
CMOS
Old Jan 21, 2018 | 01:55 AM
GaryKip's Avatar
GaryKip
Great video. Thank you for the presentation. Good Job.
