Sponsored by: Real Truck
Electric window issue
Old Aug 11, 2017 | 06:26 PM
philn's Avatar
philn
I developed a strange power window issue today. Rolled the right front window down and then it would not go up with either the individual door switch or the driver control switch. Also noticed that I could not control the right rear window with the right rear window switch but could roll it up/down with the driver control switch. I removed the right front door panel and verified that all connections were good to the right front motor. Very puzzled. Insight to this? Maybe a PCM problem? thanks. 2010 F350 Superduty Crew cab
Old Aug 12, 2017 | 10:56 AM
alloro's Avatar
alloro
For the RF, with the panel off unplug the connector to the motor. Then apply 12 volts to the 2 motor terminals and see if it goes up. Try reversing the 12 volts leads too.
Old Aug 14, 2017 | 07:55 AM
philn's Avatar
philn
Found the problem after a few days of repeated diagnosing. Applied 12v to the motor terminals initially to raise the window and the motor seemed fine. Was also getting 12v to the window motor plug. After a few days of driving, I checked again and found the same situation but the window would not move. While holding the switch in the down position, I beat on the door panel and the window moved down. Fairly certain the motor is bad at this point.
Old Aug 14, 2017 | 08:51 AM
alloro's Avatar
alloro
...or the switch.
2.7EcoBoost
2015 - 2020 F150
Aug 5, 2019 11:12 AM
Skunberg
1997 - 2003 F150
May 18, 2015 05:43 PM
Taboo
Jul 24, 2007 12:24 PM
aMw_fl
Apr 13, 2007 12:55 PM
Dutch123
1978 - 1996 Big Bronco
Nov 22, 2004 09:32 PM
