Hutch Mod Pre Pump Filter - Ultimate Thread
Old Aug 12, 2017 | 10:29 PM
F250_'s Avatar
F250_
Another fan of the Racor PS120 here. I ran the BF1212 for years, but switched to the PS120 nearly two years ago and would not do otherwise on any future diesel truck I get.
Old Aug 13, 2017 | 08:18 AM
SaintITC's Avatar
SaintITC
I mounted my Racor on the crossmember just forward of the fuel tank. It's up a bit higher than on the frame, and I didn't have to try drilling holes through that thick metal. I had a piece of 1-1/2" angle I used to make a mount to go from the horizontal crossmember to a vertical plane for the Racor. I also took an old beer cozy and some Velcro to cover it up and protect it from little things kicked up from the tires.
Old Aug 13, 2017 | 04:55 PM
dn29626's Avatar
dn29626
Wix 33972 for me.
Old Aug 14, 2017 | 02:16 PM
JT250's Avatar
JT250
Originally Posted by CousinCarl
How have you guys mounted the racor? Any concern with low clearance from the elements?
no fits within the frame rail
Old Aug 14, 2017 | 02:18 PM
JT250's Avatar
JT250
Do you clean or replace the strainer in the PS120 every so often?
I look at mine from time to time but have never had to clean it. There is some stuff in the bottom but not enough to worry about. The clear housing does screw off if you need to clean it. That is what makes this soo much better than the other options; you can tell if it needs to be cleaned rather than blindly changing a filter that probably does not need to be changed. Also it does not restrict flow.
Old Aug 14, 2017 | 02:21 PM
JT250's Avatar
JT250
Originally Posted by Walleye Hunter
I'm cheap and I'm going to do something like post #42 in this thread when I do mine. Guys have reported using some kind of Wix (I think) inline screen right before the pump and I'll go for that as well.
https://www.ford-trucks.com/forums/1...l#post17390783
Is that cleanable? If so, you have to remove it to know if it is plugged? The Racor PS120 is not that much more expensive for what you get. If you compare filter area to price the Racor is cheaper. Would take a long time to plug up the Racor.
Old Aug 14, 2017 | 02:33 PM
CousinCarl's Avatar
CousinCarl
Thanks for all the recommendations. I think I have decided to go with the Racor and piece together a kit off Amazon using Sous' list in a previously mentioned thread I was able to track down.
https://www.ford-trucks.com/forums/1...-almost-2.html
Sous, is this list still sufficient? Nothing you can look back on now and would change? I see where you put the gasoila but what about the Permatex gasket sealer? Didn't I read Hank had a fiasco of a situation with that stuff ruining his fuel system? Sorry, to bring up buried ghosts - just trying to learn from previous experiences.
From my research, seems I am just about set.Do the hutch/harpoon in tank. Double clamp all junctions; 3/8 line from sending unit to pre pump racor then 3/8 line double clamped to fuel pump and done? Missing anything?
Old Aug 14, 2017 | 03:08 PM
JT250's Avatar
JT250
Why use 3/8"? 5/16" is bigger than the stock line and you do not have to double clamp. It slides over the sending unit nicely w out having to double clamp.
Old Aug 14, 2017 | 03:33 PM
Walleye Hunter's Avatar
Walleye Hunter
Easy installation, locally available and it looks like it's see through when it's new, don't know about later, I'll let you know.
https://www.oreillyauto.com/detail/w.../33972/4833158
Old Aug 14, 2017 | 03:34 PM
liquidlounge's Avatar
liquidlounge
Originally Posted by F350-6
I went through the same thought process many years ago. I looked and looked online, and even looked through a Baldwin catalog that a supplier had given me.
On a whim I decided I'd call Baldwin and see if they could offer any help. To my surprise, they transfered me to an engineer after I gave them a brief description of what I was trying to do. Non factory application, they just wanted to advise me on what would work, regardless of what the factory set up used to be.
His advice, you already have a primary fuel filter in the engine to protect the injectors. What you need pre-pump is at least 100 micron filtration to block larger debris from entering the pump. And to block debris larger than the inlet screen on the factory pump so it doesn't become clogged.
If you put a really low micron rating filter pre-pump, then it in essence becomes the primary filter, and the fuel pump was never really designed to pull volume through that filtration.
I ran the Baldwin BF7725 for years due to the advice and attention I got. Then I decided to expand my options.
https://www.ford-trucks.com/forums/1...l#post15512691
This above. Spend your extra $$ where it will make a difference. I'm on my 2nd cheap inline filter in 10 years. Minutes to install or replace.
Old Aug 14, 2017 | 04:33 PM
1leg's Avatar
1leg
I just installed this on my truck, You really need to run a 100 micron as pre filter. I think a 40 Micron is to small for a pre filter. It's expensive put should last the rest of life of the truck.
Amazon Amazon
Old Aug 14, 2017 | 05:09 PM
dn29626's Avatar
dn29626
I don't understand why there is so much excitement about pricey filters.
Wix 33972 is around $10 and I change it about once a year, far more often than I need to.
Old Aug 14, 2017 | 05:37 PM
  #28
1leg's Avatar
1leg
Depending on were you look that is a 40-50 micron filter. IMO, that is restricting the fuel pump to much. but again just my opinion. If it works for you great.
Old Aug 14, 2017 | 05:43 PM
  #29
dn29626's Avatar
dn29626
Originally Posted by 1leg
...that is a 40-50 micron filter. IMO, that is restricting the fuel pump to much...
It is flow rated at 1 gallon per minute. That rating doesn't seem restrictive to me.
I hope my truck never consumes fuel that quickly.
I have been running it for most of 7 years.
To each his own. My .02
Old Aug 14, 2017 | 05:44 PM
  #30
Murf7.3's Avatar
Murf7.3
Here is another one you can check out. I've been running it for about a year, so far so good. I like it because it has metal barbs and you can replace the elements. However, for the cost I will just swap out the complete unit when the time comes.
https://www.holley.com/products/fuel...ers/parts/9747
