after all the upgrades I still get 15 lbs boost. on a cold morning I will see about 18 to 209 MAX! I don't have any boost leaks.
I have all the stuff on it except injectors and larger turbo.
3'' to 5'' Exhaust
Large Rifraf intake,
Tc6 chip
intercooled.
Rifraff billet wheel.
I can't remember but have you already replaced up pipe donut gaskets or not yet that could be a contributing factor big time depending on there condition
I dont have any leaks in the up pipes. I do have one started in the manifold but the boost have not changed since before the leak. Well then I'm going to start calling BS on claims of 30 lbs on stock units with a down pipe chip and air cleaner.......
I made 20 with similar. Efuel and t 500 got injectors working to potential and could get 29-30. If hpop is weak and not keeping stix stroking to potential and stock fuel sucks....there u go.
Well I'm just going to rebuild the system. I have new parts all over waiting to go in. May as well get the 38 turbo, stage 1 sticks and a new Hpop. While I am at it buy a new rebuilt engine too.
