I put my new ISSPro EV2's in last week, now I can keep an eye on what the trucks doing with the tuner it has. My question is what is good / normal boost for these things with chips? I have PHP programs on my DP chip and I noticed that while cruising highway at approx 65mph (almost 2k) my boost is 4-6psi. I can make over 20, but I need to have my foot on the floor and it's at the very top of the RPM range. It's Diesel, and it's not a Detroit, so this does not seem right to me. How do I get good boost down low where I'd like it? Say 1400-1800?? Can someone with similar mods post a vid or something so I know how it should act.
Thanks,
Wayne.
Oh, I have a pre-turbo pyro, installed in the manifold. At the same cruising speeds posted its about 600-700 deg. Foot flat on the floor in a bunch of gears it won't go over 1100, so I don't think I have an exhaust leak.
Your highway boost levels and pyro temps. sound fine but the norm at full throttle can range between 18 to 24 PSI's and anything over that your risking damage to your turbo and it starts to defuel unless you have a boost fooler. And getting your temps over 1100 isn't a good thing for extended periods of time either with a stock turbo I believe. Maybe Bill at PHP set your chip not to go over that 1100 degrees for safety reasons, give him a call.
You can spike EGTs a HELLUVA lot higher than 1300. I've nearly buried my 1600 deg gauge many, many times. I run maybe 2-3 psi and 500-600 deg on the highway @ 70ish mph, and I can bury my 35psi boost gauge when I floorboard the pedal. But I have little different configuration...
Your stock truck tuned numbers cruising sound about right, with the max boost being a little low. Are all your boots tight and in good condition? You could be losing a little boost on the high end because of a loose clamp...
Thanks,
Wayne.
I have no idea which chip it is, I got it from a buddy. It's a old school TS style six position though.
From what everyone seems to be telling me is that it's totally normall for it to not reach max boost until well over 2k rpms??? I want to make more boost earlier, thats all. I don't like to really beat it to get it to go when I need it to go.
I've never even touched 1200 on the pyro. probably won't ever either.
It's definitely making over 20 on the top end, I just can't take my eyes off the tach long enough to get an exact number. I don't like hitting the limiter, that ****s for Hondas, so I try not too.
What i'm trying to say is i want to make max boost at like 1400-2100 rpms. not 2400+ i'm never up there.
Well, your engine isn't really starting to make power until 1800-2100 rpm. If you are hitting the rev limiter I would say you need to talk to your tuner since it should be around 3000-3200 rpm.
One thing I have noticed in these older trucks, the wastegate actuator gets weak after all the heat cycling and age. Shorten the wg actuator rod 1-2 turns and see if that helps your boost. If anything it will help reduce exhaust leaking by the wg flapper and make the truck a little more responsive and all around better.
Being that you have a 6spd, you may have a little more lag then us auto guys, but even when I roll on the throttle and before boost hits, my truck lags in the boost department as well.
I will do this tonight / this week and report back. I don't drive it much, it's a toy.
