My 2018 F250 Lariat did not have BLIS...everything else but not Bliss. I hear the replacement tail lamp assembly is quite expensive...so I'll probably live without it.
Glad you figured it out. The picture attached is of the connector on the mirror, so you don't have to run inside the cab, just to the connector of the mirror wiring harness.
Got it! After reading this thread multiple times and then reading a mustang forum about a similar topic, I found the steps I was missing. Note* when running forscan do not select any saved profiles you may have for your vehicle. Let it run as if its for a different vehicle. It will then pick up the new SODL & SODR modules. Everyone's post has been a huge help. Ty
I have the puddle lights, I have pin 13 and 20 with wires in there location. So not sure why there’s no
ddm or pdm modules. It must be using another source of module
The ipc has the cta option to enable and the bliss option I can enable both. I’ll have to do some digging In the modules to see where the put the pdm and ddm info. Not quite sure why those modules are not there
See my PM to you, just confirmed the 2018's absolutely have the DDM and PDM modules, based on 2018 as-built data.
Question, I have a 2019 F-350 lariat sport on order and wondering if I have blis and and no led headlights will the rear taillights come with led lights or halogen ?
just wondering if blis adds led’s in rear taillight housing or not .
no you will have to order bliss and if you don’t get the led heads you will get halogen tails and heads. You can get bliss with halogen tails it’s 500 option
The BLIS LED connector is NOT WPT-1197 / 3U2Z-14S411-PF, even though Ford says that it is.
After inspecting the new mirror glass and finding the manufacturer (JST) of the connector on the glass side, I believe the parts below will work. I will update this post with the results once the parts arrive.
Thanks to everyone that came before me, as they majority of the leg work. I'm hoping these connectors work out so that this conversion can be done without having to replace the LED connector attached to the new the mirror glass.
Reason: Updated after testing with better information
To be honest I don't use BLIS at all. The mirror coverage is exceptional in these truck. The cross traffic alert is about 50% accurate. Goes off a lot when backing into a space or up to my garage.
Are you confusing the cross traffic alert with the back up sensors? My backup sensors go off a lot but my cross traffic alert has only gone off when I was backing out of a parking spot and a vehicle was approaching from 90 degrees. The cross traffic alert saved me once when the truck was a week old. I was at an old pull through spray car wash and the exit door broke. I was backing out and some younger driver came flying through the parking lot. The cross traffic alert system went nuts and not knowing what was happening I stopped. Kid missed hitting my by a couple feet. It said something about vehicle approaching from the right or something like that.
Roly
I'm having the same trouble. I have programmed SODL and SODR with my vin, but I am still getting U0501 and U049A (Invalid data received from door control module). I don't believe I have made any changes in the door control modules. I must be missing something.
Roly,
Do you still have any pins? I destroyed about 4-5.
I'll read the full thread shortly.
Also your PM is full. Just a heads up... [
Originally Posted by Roly
I believe I've found the pins for the 22 conductor connector so you add the missing pins instead of cutting the wires for the LED. They arrived today and they look right but I won't know until I assemble everything. If they work, I have a 100 of them so I'll be willing to mail pins to those who are using doing the swap.
Sorry no extra pins left any more, but they cheap $10 for 100 strip. Only that couple days if you order from Mouser. Will have to work on cleaning up the PM box, just not a priority.
