Blind spot nav system
#62
#69
#70
2018 f250 bliss
I swapped out to led tail lights with bliss. My truck didn’t come with bliss but I have coded In the ipc and the sodl and sodr. My truck doesn’t have the pdm or the ddm. I’m seeing the bliss and cross traffic on the dash but it says cross traffic fault and bliss system fault off. Has any one attempted this on a 18 yet. Any info would be great. TIA
#71
While everything appears to be working I noticed when comparing the as-build data between my truck and different trucks that have BLIS, there are differences besides the VIN that in just encoded by ASCII to hex.
Since we don't have a detailed description of each offset, I'm guessing that the radar module is generic part that can be configured / tuned based on the application.
When comparing as-built data from several trucks with factory BLIS, they all have the same values excluding vin information, however mime is different. I'm theorizing that the SODL/SODR modules have an out of the box configuration and we should apply the setting that are consistent from other as-built configs.
@Stoking & Steelhant - Did you update your SODL/SODR modules using IDS or have dealer updated them after adding BLIS.
If I get time today I'll update my to match what I see shipping from the factory.
The IPC, DDM, and PDM changes all appear to be correct and consistent with as-build data from other trucks.
Roly
Roly
#73
#74
Sample VIN: 1FT8W3BT3HED13111
Convert ASCII to Hex
https://www.rapidtables.com/convert/...ii-to-hex.html
Sample VIN coded for SODL/SODR
7C4/7C6-08-01 3146 5438 57xx
7C4/7C6-08-02 33xx
7C4/7C6-09-01 4254 3348 45xx
7C4/7C6-09-02 44xx
7C4/7C6-10-01 3133 3131 31x
#75
Not sure how your going to get BLIS to work without the DDM/PDM modules. These are the modules in the door that control the BLIS LED in the side mirrors.
Maybe you can get just CTA to work, but BLIS only uses the LED in the mirrors as it only indicator.
DDM/PDM 740/741-04-01 F400 xx - Turn Signals, Puddle Lamps & BLIS
OR
DDM/PDM 740/741-04-01 74xx xx - Turn Signals & BLIS - without Puddle Lamps
Roly
