Illinois Chapter Join Chapter Leader: wpnaes
Illinois Chapter July 2017 BS Thread
Old Jul 10, 2017 | 09:28 PM
  #901
56panelford's Avatar
56panelford
Originally Posted by KOESTNER
Howdy John!
How was your trip to Dryden?
Best part of the day...
Old Jul 10, 2017 | 09:30 PM
  #902
KOESTNER's Avatar
KOESTNER
What was wrong with the rest of the day?
Old Jul 10, 2017 | 09:32 PM
  #903
donjamer's Avatar
donjamer
Howdy John..
Guess you didn't get your parts..LOL
Old Jul 10, 2017 | 09:39 PM
  #904
56panelford
Pulled the transmission only to find that there is no frost plugs back there and the back of the motor is dry as chip. Can't figure out where the antifreeze came from that was definitely in the bell housing. checked around the heads and the whole outside of the motor has no indications of leaks. Going to check the rest of the frost plugs tomorrow to see if they have a possible leak and followed the oil pan. Took the transmission off for nothing. I did stop in to the transmission shop and borrowed an empty casing from an overdrive to check if it clears everything so thinking seriously now in spending the bucks now that I have it out, it does mean another new drive shaft though..
  #905
56panelford
Originally Posted by donjamer
Howdy John..
They will be in tomorrow...
Old Jul 10, 2017 | 09:40 PM
  #906
KOESTNER's Avatar
KOESTNER
Hope what Don said doesn't mean another trip?
Old Jul 10, 2017 | 09:42 PM
  #907
donjamer's Avatar
donjamer
That sucks you didn't find the leak after all that
  #908
56panelford
Gives me another break from my misery...lol
Old Jul 10, 2017 | 09:47 PM
  #909
56panelford
I guess I should have done more research to find out that Ford didn't put frost plugs there. I'm feeling dumber by the day. I did stop in to see a friend today and he had a transmission jack he lent me which made it very easy to remove..so should be just as easy to reinstall this one or a new AOD ..
Old Jul 10, 2017 | 09:49 PM
  #910
KOESTNER's Avatar
KOESTNER
Do your heater lines run over the back of the engine and the trans has a vent opening on top of the bell housing?
You're thinking a gm engine and trans swap?
Old Jul 10, 2017 | 09:54 PM
  #911
donjamer's Avatar
donjamer
That will be a big help..
Does the truck have a heater core with hoses on the firewall above the back of the engine??
Maybe the clamps are loose
  #912
56panelford
No I plan to keep it all Ford and against my better judgement... I'm pricing out overdrive transmissions and whatever else may be involved or even possibly a gear vendors overdrive..
Old Jul 10, 2017 | 09:56 PM
  #913
56panelford
I did check my hoses , the outside of the motor is dry and so is the firewall, going to check the frost plugs above the motor mounts to see if they are leaking and if antifreeze could be following the oil pan gasket back to the bell housing..only other thing I can think of..
Old Jul 10, 2017 | 09:58 PM
  #914
donjamer's Avatar
donjamer
Damn, thought I had something there..
Old Jul 10, 2017 | 09:59 PM
  #915
56panelford
You did...an idea...lol
