ill air test it just for heck of it. sad if shop charged for pump and never installed. will find out.
ok hooked air to ipr port. i hear air in turbo drain tube and a bubbling sound in oil filter housing. 100 psi. not alot of air but some. unhooked air and sprayed oil out everywhere. so what you all think?
pump be here monday. get it rest away apart and wait for it. im not giving up on it. lol
well put pump on. no luck. found out oil is over full. full of fuel so id say making oil thin. checked injector o rings. no luck. so started swaping injectors and turning pump on in between each injector. still drips out of drain plug. so im guessing a crack somewhere. head stays dry whole time. any ideas would be great. next step im gonna air test each head. this thing driving me crazy
While you have your valve covers and oil rail off run your fuel pump and look at the top of the injector cup area and see which is leaking fuel. I drained 36 quarts from my pan and found a few injectors leaking at the top of the cup area. I could see the fuel. The internal o-rings were bad. I replaced them and all was good after.
I've been watching this thread and I wasn't going to say what I was going to say. Now that you spent a bunch of money on a HPOP, let's step back and be a technician instead of a parts replace. So far you know it's making oil, so you have a leaking injector seal. You also know it has a HPO leak, it needs a air test. Let's find the diesel fuel leak. Most likely your going to find the HPO leak too
down to injectors. pressurized each head. passenger side is leaking fuel. so i took injectors out and put some old ones in it. leak stopped. so guessing id say has leaking injectors. what you think?
