Tires be coming
Old Jun 22, 2017 | 02:11 PM
OR2BAJA's Avatar
OR2BAJA
I was lucky to get S637's on our new raptor. I was going to purchase them and ship them to Camping World to have them swapped on before taking delivery.
I too have a question about lug nut torque? Any ideas? Raptor 352ts.
Old Jun 22, 2017 | 02:33 PM
Paw's 150 Lariat's Avatar
Paw's 150 Lariat
Not 100% sure but I think 110-120 lbs and use a criss cross pattern.
Old Jun 22, 2017 | 02:38 PM
OR2BAJA's Avatar
OR2BAJA
Copy that.
Old Jun 22, 2017 | 07:26 PM
Ferguson65's Avatar
Ferguson65
I don't know what Lippert recommends, but IIRC Dexter was about 110 max on 1/2" studs. 140 is far too tight unless you have 9/16 studs. The sticker on my trailer from new said 110. I'm going to aim for about 105. Installing my new Sailuns Saturday.
Old Jun 23, 2017 | 04:52 AM
Fentonjoe's Avatar
Fentonjoe
Tire guy recommended 160! I thought he was nuts so I set mine at 120 with 100psi. I'm thinking of putting nitro in them mainly for consistent pressure. I was pleasantly surprised that when I rotated my tires on my car that were installed from Costco with nitro that all the pressures were exactly where they were set 6 months ago.
Old Jun 23, 2017 | 08:01 AM
WE3ZS's Avatar
WE3ZS
That's what I saw online when I recently did my hub and tire upgrades, 1/2" studs and 110 ft/lbs. I'm running 95 PSI in my Sailuns on an 11K TT.
Old Jun 26, 2017 | 09:13 AM
Paw's 150 Lariat
Mine can go to 110 psi but I run them at 100 to 105. When they heat up they'll be at 110 or higher!
Old Jun 26, 2017 | 04:27 PM
bikerman5345's Avatar
bikerman5345
That stated pressure is the cold fill point and the manufacturer takes into account the temp rise during use. You can fill it to what it states and not worry.
Old Jun 26, 2017 | 06:47 PM
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
I know a lot of you guys are ordering or using these tires but remember one thing they are made in China.
Denny
Old Jun 26, 2017 | 06:49 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Denny
I assume you are a proponent of the new Goodyear tires that recently came onto the market?
Old Jun 26, 2017 | 07:20 PM
rvpuller's Avatar
rvpuller
No I know nothing about them but I just ordered 2 GY 215/7/17.5 G114 tires to match the 2 on the right side that look like new after 2 years of my high mileage use, they replaced 2 Sumitomo tires the same size after one blowup and destroyed the side and underside of our trailer. They are $435 each but I don't like fixing the trailer, I also used GY G614 G ties and after 2 failures one doing damage I won't ever use them either. I'm just saying I don't trust Chinese tires.
Denny
Old Jun 26, 2017 | 09:48 PM
WE3ZS's Avatar
WE3ZS
True, the Sailuns are made in China, but they do come from an ISO compliant facility, so quality and quality control should be in the top tier. That is not the case with most of the typical China Bomb ST tires. They are actually commercial all position all steel tires relabeled as STs for this market and towable RV service. They have earned a pretty good reputation with RVers over the past few years.
guitarpicr
Jul 10, 2011 08:33 AM
Thomasm67
Kansas Chapter
Mar 13, 2011 07:23 PM
SBastow
Oct 16, 2009 01:57 PM
Hotwheelbill
Nov 28, 2006 11:01 PM
