Truck locks up at 45-50 mph
Hello I am new to this site but I have had this issue for allitle while now and can't seem to pin point the problem. I have a 2003 6.0l f250 disel and when I am driving and get up to around 45 mph it will shift and start to shake the whole truck and even if you mash the throttle RPMs won't move and will not gain speed until you let off the throttle and then re engage but it will continue to do this and I cannot seem to figure out what is wrong. Any help would be greatly appreciated.
Welcome to FTE,
Just an fyi - you can have codes without having a check engine light.
The reason for asking for information is that these engines are complicated and it is expensive to guess.
It is certainly good to know what work has recently been done.
What HPOP was put on (Ford or aftermarket)?
What injectors were installed (Ford or aftermarket)?
How recent was the work at the shop?
We had bad injectors both times and this last time was a no start because of the hpop. I figured the issue was due to the injectors or maby because the leak in the hpop system but it still is doing it. And I have tried both scanners one is dashboss and one is a superchips flashpaq. I will rescan tonight to see if I get something but.
That is the best advice so far.
I have been having issues and random codes popping up with a custom tune in the truck. Flashed back to stock drove it for a week. Issues gone.
Used an SCT canned tune for a week and no issues.
So my custo tune may have gotten scrambled some how.
Alec94F150XL
17
08-03-2011 04:09 PM
12secondstang
06-18-2008 11:00 AM
