RPM's hang between shifts
Old Jun 17, 2008 | 03:54 PM
12secondstang's Avatar
12secondstang
Hello,
'96 F150, 5.0, 5 speed, 2wd.
Between shifts it holds the current rpm for a few seconds then comes down real slow if I hold the clutch long enough and wait. Could the TPS cause this condition or should I be looking elsewere? This has been an ongoing issue. Not a BIG problem but an annoyance that may be affecting mpg's. Truck runs fine though a little low on power under 2000 rpm's.
There are no codes present. I just replaced the PCM to solve for code 0443 a mounth ago. I was hoping that would have magically fix all thing but not so. Thanks
Old Jun 17, 2008 | 09:20 PM
DJdemon6696's Avatar
DJdemon6696
chek the TPS..
Old Jun 18, 2008 | 11:00 AM
icrman's Avatar
icrman
The throttle cable could be coming apart, check the return spring for throttle, make sure the throttle is comming back to the idle stop. The linkage for the pedal could be sticky too.
Gufunk
Dec 29, 2013 07:39 AM
carlb254
1983 - 2012 Ranger & B-Series
Oct 31, 2013 11:37 PM
mr.fordneck
Jun 24, 2012 12:46 AM
b4hntn
1978 - 1996 Big Bronco
25
Sep 22, 2008 06:26 AM
