Engine hesitation?
Old Oct 24, 2010 | 03:35 PM
BrandonT71's Avatar
BrandonT71
Engine hesitation?
Recently I've noticed a hesitation which I am unsure about. Here's the rundown. While driving around town at speed ranges of 25-35 mph, on level ground with no load, and in 3rd gear, AT, RPM range 1500-1600, I've noticed that if I am just using enough throttle to maintain speed, say about 1/8, that the motor begins to hesitate. Its not bad, just a slight "surginess". At first I thought it may be "operator input", as some of local roads are a bit bumpy, and that vibration was translating from my foot to the accelerator pedal. However, a section of the main drag in town was just re-paved and is smooth as butter, and the hesitation, or "surginess", still exists. Additionally I've noted that if I either completely let off of accelerator, or if I give it more throttle, the symptom disappears, and will reappear if throttle input is returned the same approx. 1/8, to maintain speed. Was wondering if this could a TPS going bad or if fuel is lagging since in-tank mods have not been done, or some other issue. Any advice on a direction to look in would be greatly appreciated.
Old Oct 24, 2010 | 06:17 PM
Visseroth's Avatar
Visseroth
Could be 3 things, a injector starting to stick a little bit, IPR needs to be cleaned or replaced or like you said a dead spot or what is starting to be a dead spot in your TPS.
Old Oct 25, 2010 | 04:03 PM
BrandonT71's Avatar
BrandonT71
Forgive me for sounding stupid, I'm not a diesel genius, but if the IPR needed attention, wouldn't there be more or less a constant performance issue? And is there anyway to test the TPS, or will I need an AE or some other type of scanner?
Old Oct 25, 2010 | 06:03 PM
BrandonT71's Avatar
BrandonT71
Does anyone else wish to put in their .02?
Old Oct 25, 2010 | 07:09 PM
Shake-N-Bake's Avatar
Shake-N-Bake
A bad injector gives a similar symptom accompanied with a noticeable vibration from 45-60 mph in O.D with the TC locked so I don't think this is your issue.
I think a bad IPR would show symptoms in all gears.
If your fuel system was clogged at 1/8 throttle then your engine would fall on it's face at full throttle...so that probably isn't the issue.
If you have access to an AE, watch the voltage from your TPS and see if there is a dead spot. Have someone watch it while you duplicate the symptom while driving. If you do a search, you will find a post by PaysonPSD that shows it's possible to change just the sensor and not the whole assembly IF you have a certain arrangement. You might be lucky and can go that route for not too much expense.
Hope you find the issue soon. BTW, if/when you get gauges....I recommend Fuel Pressure for just this sort of issue.
Old Oct 25, 2010 | 07:34 PM
BrandonT71's Avatar
BrandonT71
Thanks fellas, the TPS is what my gut tells me. I'll have try and find a member near me with an AE or save my pennies and get one myself.
Old Oct 25, 2010 | 07:37 PM
Shake-N-Bake
Here is that thread that Robin posted back in the spring.
Hope this helps.
https://www.ford-trucks.com/forums/9...ensor-fyi.html
Old Oct 25, 2010 | 08:01 PM
BrandonT71's Avatar
BrandonT71
Just checked the skinny pedal, and it has the 5 wire integrated TPS/IVS, so if it turns out to be the culprit guess I'll be replacing the whole assembly.
Old Oct 26, 2010 | 11:00 AM
Shake-N-Bake
If you find the TPS is the issue, I would try some electronic spray cleaner first. Could be a bit dirty down there and it might fix your issue.
Old Oct 26, 2010 | 11:44 PM
BrandonT71's Avatar
BrandonT71
Thanks for the tip. Don't have a AE yet, so think I'll give that a try and what comes of it.
Old Oct 27, 2010 | 09:32 AM
bama29fan's Avatar
bama29fan
it's not that bad...i replaced mine for less then $100 shipped from partsguyed
Nathan Vos
May 18, 2019 02:33 PM
78 Ford F150 460
1978 - 1996 Big Bronco
42
Jan 24, 2017 08:05 PM
78 Ford F150 460
16
Jan 5, 2017 07:55 PM
Parsedout
20
Apr 12, 2015 12:18 PM
Ricohman
Modular V10 (6.8l)
Oct 2, 2010 03:14 PM
