2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Replace Sunroof Glass
Old May 28, 2017 | 07:17 AM
Big's Avatar
Big
2010 Expedition Limited, 158,000 miles. My wife pulled in the driveway yesterday and heard a loud pop. She looked up and saw that the sunroof glass had shattered. It is not likely that anything fell on it - we don't have any trees around, and I looked on the roof for some projectile and found nothing.
Anyway I have looked all over the ulranet for DIY info on removing just the glass from the truck and found nothing. A lot of track repair posts and a video or two, but nothing showing the glass removal part. Being it is Memorial Day weekend, the local dealer parts department was closed so I couldn't call and talk to them. I have found some replacement glass and seals on eBay and the pictures seem to indicate that 4 torx screws hold the glass in place.
Can anyone confirm?
Looks like these (4) screws hold the glass/frame in place.
Old May 28, 2017 | 09:27 AM
alloro's Avatar
alloro
That is correct, remove those 4 torx screws and the whole frames lifts up. FYI, after the new glass is in, those same 4 screws are used to adjust the glass to make it level with the roof. After that adjustment is done pick 2 of the screws in opposite corners and loosen then tighten them one at a time. This will relieve any twisting strain on the glass that might have occurred during the adjusting process.
Old May 29, 2017 | 07:03 AM
Big's Avatar
Big
Thanks Alloro. I'm also seeing the seal as a part of the sunroof assembly. Is that something that is destroyed in replacing the glass or should it be reusable?
Old May 29, 2017 | 09:36 AM
alloro's Avatar
alloro
The glass seal and frame are an assembly, just go to any junkyard and pick one out. Take out the 4 torx screws, swap the frames and reinstall the 4 torx screws, and adjust. Trying to buy just the glass is going to create a lot of extra work with no real cost savings.
Here are some junkyards in your state that have the glass.
http://www.car-part.com/cgi-bin/sear...erPage=1&iKey=
Old May 30, 2017 | 07:09 AM
Big's Avatar
Big
Thanks!
Search Results
Thanks Alloro.
Old Jun 6, 2017 | 10:44 AM
Big's Avatar
Big
Quick follow up on the sunroof:
Picked up a used glass from a local yard for $80, including the seal. Like Alloro said, seal comes with the glass. Removing the four torx screws is all that is needed to remove/replace the glass. A little bit of adjusting from the inside and you are back in bidness.
Old Jun 6, 2017 | 12:39 PM
alloro's Avatar
alloro
Glad it worked out okay. Did you spray it with a hose or go through a car wash to make sure it doesn't leak before rain comes?
Old Jun 7, 2017 | 02:59 PM
Big's Avatar
Big
SWMBO washed it the next day. Phone did not ring in a panic so I'd say it's good.
Old Jun 8, 2017 | 09:04 AM
alloro's Avatar
alloro
SWMBO
Okay you got me, what is SWMBO?
Old Jun 20, 2017 | 12:00 PM
Big's Avatar
Big
Sorry that I haven't checked in lately.
SWMBO = She Who Must Be Obeyed
Old Jun 21, 2017 | 09:15 AM
alloro's Avatar
alloro
Oh LOL, I though it was the name of some car wash chain.
slowrollerzcustoms
Jul 12, 2014 01:14 PM
Oakroadjoe
May 15, 2011 10:56 PM
qman
Oct 18, 2006 01:46 PM
texasgoat
1978 - 1996 Big Bronco
Dec 24, 2004 03:10 PM
