1990 XLT strange ignition issues
Old Jun 20, 2026 | 04:51 PM
Canthelpmyself's Avatar
Canthelpmyself
4wd Low
1990 XLT Lariat 5.0 4EOD. Had previous issues getting it rolling, sorted that out with new TPS. Pulled the ECM and sent it off for repairs, reinstalled today. There is intermittent loss of power at the ignition switch, sometimes there is power there and sometimes not. Couldn’t get it to start, put the battery on a charge as it sounded like the solenoid would click but that’s it. After a few hours of charging switched the charger to start mode and got it to fire up and idle nicely. Then it died as soon as I put it in reverse. Hasn’t started since, same intermittent power issue at the key. The only things I did while the ECM was out was swapped in new headlight assemblies, new wiper motor, new stereo, and welded in new floor / inner cab panels. I will start checking things out with the meter tomorrow, just thought I’d ask in case anybody else had already beat their heads against the wall over something like this.
Old Jun 20, 2026 | 04:59 PM
90project5.0's Avatar
90project5.0
Not second guessing you, but how do you know you’re losing power at the ignition switch? On the starter solenoid battery terminal, make sure those are secure. Since you changed headlight housings, did you unhook any wires? Like a ground? Battery terminals themselves are very tight and in good order?
Old Jun 20, 2026 | 06:44 PM
Canthelpmyself
4wd Low
I’m happy to be second guessed, the only wiring I touched doing the headlights and wiper motor were the harnesses to those items. I will go back over the areas to make sure I didn’t knock anything loose. I’m not sure yet whether power is making it to the ignition switch, at this point all I know is the when I turn the key either to accessory power or ignition nothing happens. Until it does lol. I can cycle the key many times when it isn’t working with no results, then I can walk away for a while and come back and get power but no ignition. Battery clamps are nice and tight, I don’t a load tester but the meter shows me 13.4 volts so at least I know there is enough potential to at least get the solenoid moving.
Old Jun 20, 2026 | 06:56 PM
90project5.0
I would test for voltage in and out of the switch in the different positions. Could very well be a bad ignition switch. It doesn’t sound to me like it’s out of alignment being intermittent.
Old Jun 21, 2026 | 07:34 AM
tjc transport's Avatar
tjc transport
i ain't rite
these year trucks are known for the ignition switches separating between the Aluminum and plastic pieces.
i have replaced at least 100 of them over the past 40 years.
Old Jun 21, 2026 | 08:18 AM
manicmechanic007's Avatar
manicmechanic007
^^ This^^
Also, check the ignition switch actuator
You got bells and whistles when you turn the key on and off? (dash lights up)?
Old Jun 21, 2026 | 08:20 AM
My4Fordtrucks's Avatar
My4Fordtrucks
…and the actuator breaking which explains why there is a replacement thread in the “Sticky” section.
Old Jun 21, 2026 | 03:40 PM
Canthelpmyself
4wd Low
Thank you for all the tips, I dropped the steering column and pulled the switch. It was good but there was no power. Traced the wiring back and found a corroded crimped end at the solenoid. Crimped on new terminal and problem solved. Guess there had been just enough meat left on it to start previously but once I started screwing around in there I must have shook it loose. Successfully got the truck moved away from the side of the garage to start welding in new floor / rocker patches on that side now. I like a project but haven’t worked on old stuff for a while, forgot how they start throwing hissy fits when you mess around and starting changing stuff.
Old Jun 21, 2026 | 04:23 PM
90project5.0
Easy fixes are always nice! Good luck on the resto and post pics of work!
Old Jun 21, 2026 | 04:35 PM
Canthelpmyself
4wd Low
Started with this mess. Complete with a mouse nest. Brought the cat over to give him new purpose.
Found enough solid steel to weld in this patch panel to match up with the dogleg curve
Formed up a patch for the dogleg, took me more time on that little patch with all the curves than I was expecting.
Ordered a floor panel and just cut out what I needed. Also cut out smaller sections to patch in where the kickplate screws into the floor, those penetrations were drastically eaten away. When it comes time to reinstall I am going to mark the hole and drill in some rivnuts and then undercoat the whole thing. Should be solid for as long as I own the rig.
I have several welding tickets in different processes but not a ton of experience with small gauge steel. I felt like I was tacking my life away.
Old Jun 21, 2026 | 04:49 PM
90project5.0
Looks good to me!! I have zero experience with any welding, but I really want to have a cowl hood and not spend $1k for a mural ready hood or pin on… soo smart thing to do was buy a cheap welder on amazon and practice before I start. I learned the first welder I bought couldn’t go low enough voltage and ate anything thinner than 16ga in half a second! Bought the next step up, but haven’t been able to mess with it yet. I’ll get it! It’s been a learning curve for me and my son when he visits. This fall, we will be building it one way or another! I’m sure I’ll Be buying plenty of bondo..
Old Jun 21, 2026 | 05:04 PM
manicmechanic007
Man card stamped
Old Jun 21, 2026 | 05:15 PM
Canthelpmyself
4wd Low
Without knowing what kind of welder you’re using there is a huge difference between a flux core machine and a gas mig machine. Flux core runs electrode negative which puts all the heat on the work piece, gas is electrode positive so it’s easier to control the heat. I tried using a flux core machine to start but was making a mess so I pulled the pin and bought a 180 amp 110/220 gas machine. I’d been wanting one for a while but never pulled the pin because I didn’t have a use case for it. The last old truck I had was a 1990 Tacoma that was a rolling advert for bondo lol, it gets the job done. This Ford doesn’t need to be on the road every day so I decided to take my time and do it this way so that either I or the next owner wouldn’t have to worry about it.
Old Jun 21, 2026 | 05:17 PM
Canthelpmyself
4wd Low
Man card stamped
just doing my part to show the soft hand kids at the office how to get **** done!
Old Jun 21, 2026 | 05:27 PM
90project5.0
It’s a flux cored mig. I know gas is a lot better, but by the time I bought the machine, the gas and stuff I still needed, that blew my budget! That gas ain’t cheap.. I do not ever plan to be a pro, I just need to fix my broken equipment and tinker with the truck haha!
This is the new one, haven’t messed with it yet. I’m using .030 flux wire.
pba369
May 21, 2023 07:37 AM
scootro5.0
Nov 27, 2018 06:32 PM
ef150owner
Jul 28, 2012 07:06 PM
cr506
Electrical Systems/Wiring
Jun 16, 2009 07:04 PM
beastybronco
1978 - 1996 Big Bronco
Aug 2, 2004 08:13 AM
