Glass Removal
Old Jul 11, 2014 | 02:44 PM
slowrollerzcustoms's Avatar
slowrollerzcustoms
Glass Removal
I need to know the best and easiest way to remove the glass from my 78 supercab without breaking. the windshield and back glass i dont care they are garbage but the side glass is still good
Old Jul 11, 2014 | 05:50 PM
Canus's Avatar
Canus
You're going to have to buy new rubber anyhow so just use a box cutter to cut the old rubber to facilitate the glass removal. That's what I did on mine and had NO problem removing the old glass without damaging it.
Old Jul 11, 2014 | 07:49 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Like he said and then start thinking about going from fixed glass to pop open ones....JY time.
slowrollerzcustoms
Thanks for the knowledge i now have all the glass out of my cab
Old Jul 11, 2014 | 07:52 PM
slowrollerzcustoms
what model will i need to use to get pop outs and what model of f150 can i get the dark tinted solid glass from
Old Jul 11, 2014 | 08:51 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Any Supercab model from 74-79 will work (the Supercab model came out in '74). By "dark tinted", if you mean smoked tint, that's aftermarket. From the factory, Ford only offered the light green tint.
Old Jul 11, 2014 | 09:18 PM
77&79F250's Avatar
77&79F250
X2 on any 74-79 2wd or 4wd F150, F250 or F350 that is a SC, nothing newer will work.
Old Jul 11, 2014 | 09:22 PM
slowrollerzcustoms
cool thanks
slowrollerzcustoms
well i do have lmc truck in my back yard too
Old Jul 11, 2014 | 09:26 PM
77&79F250's Avatar
77&79F250
They do not sale the replacement pop out window parts, just the glass and both style seals. Hinges and lock/un-lock levers are JY items I do believe.
Old Jul 11, 2014 | 09:37 PM
slowrollerzcustoms
ok ill put a look out for a set
Old Jul 12, 2014 | 06:19 AM
ranger429's Avatar
ranger429
How do you know that without seeing what he had? His might of been in perfect shape to reuse. I've removed the back and front glass plenty of times and reused the OE rubber. There is no need to take a razor knife to either of those.
Old Jul 12, 2014 | 01:14 PM
slowrollerzcustoms
The rubbers were shot so it did not bother me to cut them
pbsdaddy
Jun 2, 2015 08:54 PM
Oakroadjoe
May 15, 2011 10:56 PM
vintage tin
13
Sep 9, 2009 02:04 PM
yeha4x4
Appearance & Dress-Up
Mar 3, 2005 05:03 PM
