1978 - 1996 Big Bronco
vent glass
Old Dec 22, 2004 | 02:42 PM
texasgoat's Avatar
texasgoat
vent glass
92 ford full size bronco. Is it necessary to remove the entire assembly on the broken vent glass or will the new piece of glass simply slide in the void left by the old broken out glass without removing the assembly???Thanks guys.
Old Dec 22, 2004 | 03:55 PM
MatthewC's Avatar
MatthewC
Much much easier and cheaper to go to a junk yard and buy the whole assembly. It installs with 3 simple bolts.
-Matt
Old Dec 22, 2004 | 04:18 PM
texasgoat's Avatar
texasgoat
vent glass
I already have the glass. I just need to know if I have to remove the whole assembly for the glass to be able to slide in or can I install the glass with the assembly in place. Thanks
Old Dec 22, 2004 | 05:08 PM
BroncoRoadKill's Avatar
BroncoRoadKill
I think you have too take the assymbly out and take it apart, but I could be wrong.
Old Dec 23, 2004 | 08:46 AM
texasgoat's Avatar
texasgoat
vent glass
does anyone know the real answer to the question of assembly removal or no. Thanks
Old Dec 23, 2004 | 03:40 PM
MatthewC's Avatar
MatthewC
Im not absolutely sure, but I think the whole rubber assembly that surrounds the glass must be removed to install the new piece of glass. To do this the whole assembly must be removed from the door, so yes.
-Matt
Old Dec 24, 2004 | 01:21 AM
greystreak92's Avatar
greystreak92
The metal frame does not have to be removed. The rubber seal is glued in so it must be cleaned out of the channel in the frame and a new seal installed. Most glass replacement shops will just back fill the channel with sealer and slide the glass into the frame. In short, no, the frame does NOT have to be removed to replace the glass it will slide into the channel. I've had this done three or four times (yeah well I have to park in some rotten areas at times) and watched the guys replace it every time. The replacement guys usually use a cordless drill to ream the rubber and adhesive out of the channel before installing a new seal and the glass but they have never removed any fo the frame from the truck to do so.
Old Dec 24, 2004 | 08:07 AM
tex94F250's Avatar
tex94F250
Yep, done it. Greystreak92 is absolutely correct. You can get a new seal and use a good silicone to mount when sliding glass/seal in. Clean up when it cures as the silicone serves as an installation lubricant/bonding agent. Carefully use a rubber mallet to lightly tap the back edge of the glass in to seated position. I had a friend hold the front edge of the frame from the inside when installing. Once cleanup is done you're back in business.
Tex
94 F250 460 cid E4OD 4x4
and formerly 96 Bronco owner
Old Dec 24, 2004 | 03:10 PM
JBronco's Avatar
JBronco
I've done this swap after someone smashed my vent window, to get an amp and some speaker boxes...
I just cleaned the old glass out of the channel with a screwdriver and siliconed the $15 boneyard glass in. It was simple, I don't see why someone would want to take off the door panel and unbolt a bunch of stuff when it is not necessary.
