Tranny trouble
Old May 27, 2017 | 12:02 PM
Daniel Dunn's Avatar
Daniel Dunn
Tranny trouble
1995 ford van --won't start out in drive have to shift into 2nd gear to take off then to 3rd -- replaced tranny & same thing happening. Blew that tranny - so I put another tranny in - same problem think in its not the tranny but maybe a sensor or computer problem -this is the year before they went full blown computer read out .... Anybody got any ideas
Old May 27, 2017 | 02:02 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Yes, I have ideas. I think something is wrong. With all the specifics in your post that's all I can say with any confidence.
If I knew what engine and transmission you have I'll bet I could get much more specific. And I have no idea what you mean by the year before full blown computer read out. All automatics in 1995 were 100% computer controlled.
Old May 28, 2017 | 04:11 PM
jeffreyclay's Avatar
jeffreyclay
Run your VIN# in one of the free searches to nail down the year of manufacture. Case in point, I bought a 1993 E150 (as described on the title) and discover it was a 1994.
VIN Decoder
Old May 28, 2017 | 04:19 PM
cadjak's Avatar
cadjak
Is the ABS light on? Either way, check out the speed sensor mounted on the rear differential. If it is badly gunked up replace it and if that fixes the problem, open and inspect the rear end for damage. I just went through a "sorta" similar issue on my 94 Chateau and the speed sensor going wonky effected shifting not too different from your problem. Led to my finding problems in the rear diff.
Old May 31, 2017 | 06:04 PM
boxdin's Avatar
boxdin
Sounds like its going into "limp home" mode.
Old Jun 7, 2017 | 06:40 PM
baddad457's Avatar
baddad457
Sounds like the PSOM is out in the speedometer cluster. Wreaks havoc in the transmission trying to drive it.
Old Jun 11, 2017 | 06:41 PM
95E150-'rustbucket''s Avatar
95E150-'rustbucket'
I had tranny trouble, too. I just made him go put on a prettier dress and heels.....
...Oh, wait a darn minute, you are probably talking about transmission problems! Just ignore that first line.
All assholiness aside, I had a similar problem with getting my '95 started a year ago or so. It turns out that the cable to the transmission is attached to the transmission selector shaft with two screws. One of the two had backed out then fallen out completely; the other was still attached but just barely. Reinserting and tightening those 2 screws fixed my problems.
I know, I know. The chances of that being the fix for the OP are infinitesimal. But what could it hurt to check?
Old Jun 12, 2017 | 08:48 PM
baddad457's Avatar
baddad457
I was going to lead off with: If you don't want tranny trouble, stay away from trannies !
Old Jun 16, 2017 | 12:06 PM
95E150-'rustbucket'
clarification, I think...
"this is the year before they went full blown computer read out ...."
= OBD-II
Old Jun 16, 2017 | 01:39 PM
Mark Kovalsky
The original poster was obviously not interested in any of our answers. He's never been back.
Old Jun 16, 2017 | 02:24 PM
Teutonics's Avatar
Teutonics
If I ever had/have transmission problems I hope you're the first person to answer!
Old Jun 17, 2017 | 01:50 AM
95E150-'rustbucket'
"The original poster was obviously not interested in any of our answers. He's never been back."
Either that or someone's answer helped him figure out his problem and he ain't polite enuff to say thanks. So, now he's toolin' down the road, waiting to blow another tranny .....uh, transmission.
Old Jun 17, 2017 | 08:19 AM
Mark Kovalsky
There wasn't enough information to give any useful answer. The only "solution" I saw above was to check the speed sensor. That can't cause the problem the OP has.
50swildbill
Mar 21, 2011 05:08 PM
fordman837000
Dec 12, 2007 12:55 AM
Fordbyford
1978 - 1996 Big Bronco
Sep 1, 2005 05:10 AM
Crazyromi
Nov 4, 2003 08:54 AM
