Timing
Old May 12, 2017 | 10:35 PM
jmtbiggin's Avatar
jmtbiggin
Timing
What do you guys running timing at. Mine is set at 6°( or 8, cannot remember,whichever was specified under hood). Engine runs fantastic. Starts super easy. Pull strong thru rpms. And the but is it wants to die 1/2 time when come to a stop. Starts right up no problem. Could idle speed need increasing since I retarded the timing.FYI, I am a real rookie at this
It ran fine at the 10° it was at and did not stall
300 1bbl yfa 4spd no emissions equipment
Old May 12, 2017 | 11:02 PM
Carloespo's Avatar
Carloespo
I believe that 10° BTDC is the proper setting.
Old May 13, 2017 | 09:35 AM
Harte3's Avatar
Harte3
Set the timing wherever YOUR engine likes to run. Usually anywhere between 6*-10* is good for a starting point.
Old May 13, 2017 | 10:17 AM
Tedster9's Avatar
Tedster9
^^^ This. Depends on how the truck is used. If you're not routinely hauling loads of gravel set it up to take as much timing advance as it will stand just short of any ping or detonation. It will run cooler and get better mileage, etc. Check for difficulty starting when hot.
Old May 13, 2017 | 02:11 PM
The Frenchtown Flyer's Avatar
Do you have a throttle dashpot on your carb linkage. Those were used to cure the problem you described. They look about the size of a checker with a threaded stud in the middle of it.
Old May 13, 2017 | 08:50 PM
jmtbiggin's Avatar
jmtbiggin
Will time it back to 10°. The heaviest work it will see is my big area and a riding mower.
Throttle dashpot??
Old May 15, 2017 | 10:20 AM
HoustonDave's Avatar
HoustonDave
On the rear of the YFA between the carb body and the throttle linkage; will have a single-wire electrical connection on the fender side. One of those set-once-at-tuneup-forget-forever items.
Old May 15, 2017 | 11:45 AM
I forgot that some were electric. Earlier ones were a dashpot. Right on
OldRed460
Apr 28, 2006 05:28 AM
sjim46
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Mar 27, 2004 11:34 PM
mohavi
Feb 18, 2004 10:41 PM
Samsonitesamsonite
Jan 5, 2004 04:50 PM
Old5
Feb 26, 2003 01:55 PM
