pickup coil
Old May 13, 2017 | 01:47 PM
glen_melton's Avatar
glen_melton
pickup coil
I have a 79 F150 with a 300 thta has a stumble issue. It idles good vacuum is holding steady at about 18.5. The stumble starts about the same place on my test drive and continues off and on through out the rest of the drive Its stall out a couple of times but started right back up. Ive been through the fuel system and it all seems good so I started in on the electrical. Replaced the coil and the ignition box with no change. I replaced the pickup coil with a ME52 from Orielys , two of them. I wont even turn over, it almost wants to start when turning the key back to off. put the old pickup back in and it will start right up. I see that the reluctor has a curve in it along the edges of the blades, does this need replaced to work with the new pickup or is there something else going on?
Thanks for any help.
Old May 14, 2017 | 11:16 AM
F-250 restorer's Avatar
F-250 restorer
I replaced mine about 1 year ago. I used the old relucter. I didn't like the 'made in China' label on mine, however, so I returned it and bought a NOS (new, old stock) MotorCraft one on ebay.
Good luck.
Old May 14, 2017 | 12:20 PM
glen_melton
Id rather have NOS as well, if anyone has the part numbers for the pickup and reluctor. The tag on the distributor says D5TE-12127-FA. Looking at ebay for that, Id buy it.
After looking through the forums I believe I know what happened, one of the screws on the pickup plate was loose, it must have been moving around and rubbing against the reluctor causing wear on both parts. want to get that taken care of in hopes it is the cause of my stumble. Only other thing i can think of is a interment short in a wire somewhere.
Old May 14, 2017 | 03:09 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by glen_melton
I'd rather have NOS as well, if anyone has the part numbers for the pickup and reluctor.
The tag on the distributor says: D5TE-12127-FA = Ford part number: D5TZ-12127-F .. Distributor (Motorcraft DA-1442) .. Looking at ebay for that, I'd buy it.
D5TZ-12A112-A .. Stator aka magnetic pickup coil (Motorcraft DU-5) / Obsolete ~ Available NOS & from auto parts stores.
1975/79 F100/350 & Econoline 300 I-6.
What are you calling a reluctor, that round piece with blades? If so: D5DZ-12A099-A .. Armature (Motorcraft DT-6) / Obsolete ~ Available NOS
1975/79 F100/350 & Econoline 300 I-6 // 1975/77 Maverick/Comet & 1975/79 Granada 200/250 I-6 / 1978/79 Fairmont/Zephyr 200 I-6.
Old May 14, 2017 | 03:32 PM
glen_melton
1980 FORD E 150 ECONOLINE Distributor Reluctor Parts
of course that one is the wrong one for me. thanks for the numbers
Old May 14, 2017 | 04:50 PM
glen_melton
ordered those two parts on ebay, wont be here til the end of the month, twiddles my thumbs until then.
Old May 16, 2017 | 07:47 AM
One79one71's Avatar
One79one71
It seems you have multiple issues. 1 ignition switch issue, your pickup coil issue and probably a fuel issue if it starts to stumble at the same spot during your test drive. I had similar problems and cured the fuel issue. My carb bowl was running dry, adjusted carb float, went through hoses and eventually found my pickup tube in the tank rusted out to where i was getting air in the fuel.
Eddie Maxwell
May 5, 2017 12:53 AM
daveengelson
Sep 26, 2016 11:55 AM
1977F250XLT
May 5, 2016 12:32 AM
brian1080
17
Aug 14, 2012 09:35 PM
bigbabyiniraq
Nov 3, 2008 06:54 PM
