Timing
Old Apr 27, 2006 | 08:16 PM
OldRed460's Avatar
OldRed460
Timing
hey everyone, ok so i just set my timing on my truck {1990 F250 460EFI} it had 0 degrees in it and when set to 10 degrees TDC it loved it alot and run really nice, can i set it to 12 or 14 and will this make any difference?
Old Apr 27, 2006 | 09:44 PM
SwOkcOffRoader's Avatar
SwOkcOffRoader
i see no problem with it, thats how i set my timing, by going back and forth 2 degrees at a time and see how it acts.... but my engine is much older and i dont know how different the ignition setup is....i have mine at 12 for normal driving, and i bump it up to 14 if i want some more juice at the expence of a little fuel mileage...
Old Apr 28, 2006 | 01:32 AM
turbo2256d's Avatar
turbo2256d
did you set it with the shunt removed
Old Apr 28, 2006 | 02:44 AM
OldRed460's Avatar
OldRed460
yes i removed the spout connector, so everyone agrees on a little more timing?
Old Apr 28, 2006 | 03:00 AM
turbo2256d's Avatar
turbo2256d
12 initial might be ok for street but I wouldnt recomend 14 except as a bump up at the strip then put it back.
Old Apr 28, 2006 | 05:28 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome turbo to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
