Help Identifing
Old Dec 24, 2017 | 12:00 AM
DirtyFerd's Avatar
DirtyFerd
Originally Posted by dwhawkins89
Dirtyferd, it has the ridge. And i dont mean any disrespect, but there has to be a more exact way to determine an engine, versus a number of valve cover bolts and if theres a ridge or not. there has to be number or something somewhere.
I thought we determined long ago that you had a 351W. If you have the block with the ridge, but still have 8 valve cover bolts, then you have a Clevor. That's a 351W with Cleveland/Modified heads, which is very unlikely. Just post up a pic.
Old Dec 24, 2017 | 08:33 AM
dwhawkins89's Avatar
dwhawkins89
second guessed myself after a couple 351 gaskets were wrong and 302 gaskets were right.
Old Dec 26, 2017 | 02:14 PM
Conanski's Avatar
Conanski
All windsor family motors(289, 302, 351) use the same head gaskets, so the best explanation is that those "351 gaskets" were for a 335 series engine.. 351/400m.
Old Dec 31, 2017 | 09:16 PM
baddad457's Avatar
baddad457
question guys. This same engine, has a 351 oil pump M-83 at autozone; but I thought the thermostat housings on 351 came out of the block? This one comes out of the intake. thanks as always
Well if you really want confusion, Ford built 4 different 351 engines over the years. Windsor, Cleveland, Modified and the older FE series 352 which also had the same bore/stroke as the 351's
ranger69f1
Sep 9, 2013 01:18 PM
Jordan901
Jun 21, 2008 02:12 PM
NovaRod
General Automotive Discussion
Oct 17, 2004 03:17 PM
NewMexF250
Mar 19, 2004 05:18 PM
raphael188
Aug 9, 2003 07:19 PM
