Engine Identification
Old Jun 20, 2008 | 11:16 AM
Jordan901's Avatar
Jordan901
Hey everyone,
I'm trying to figure out exactly what kind of engine is in the '81 F150 I have. I 'm not the original owner, and I don't think it's stock. It's a V8, and I have some info that might help:
Number on top of engine: E6TE-9425-EA
Number on carb: 1DM2J
Firing order: 13726548
Oilpan: has 22 bolts, and 2 drain plugs (2 low spots, like an upside-down "U")
Trans: it's attached to a C-6 transmission (which is stock)
If anyone could help out, thanks in advance.
Old Jun 20, 2008 | 01:08 PM
Franklin2's Avatar
Franklin2
Definitely not the original engine. The double sump pan with 2 drain plugs is from a late model car. If it has 6 bolts holding the valve cover on, then it's going to be a 255, 302, or 351w. Let's hope it's a 302 or 351w, since a 255 is not worth the effort to swap in. Here's how to tell the difference between a 302 and a 351w.
P.S. "E6" is an 86. That is just the casting number though, so it is not definite what year the engine is.
Old Jun 20, 2008 | 07:24 PM
Jordan901's Avatar
Jordan901
thanks for the info. I'm having a lot of trouble trying to find out what's going on in there though, and I can't tell if there is a space or not. Is there any other way at all to tell what the engine is?
I got the number off the exhaust manifold, if that helps: E0TE-9431-CA
Old Jun 21, 2008 | 02:12 PM
joestratton1's Avatar
joestratton1
measure across from valve cover to valve cover if its around 11 inches its a 302 if its around 14 inches its a 351
Aune163rd
May 27, 2016 08:06 PM
ghott
Mar 25, 2016 12:00 PM
shep71804
17
Jan 6, 2013 05:41 PM
gingerbreadmaniac
Dec 13, 2008 08:27 PM
dcdave
Feb 4, 2006 11:56 AM
