Sea foam
Old May 10, 2017 | 11:29 PM
1911fan's Avatar
1911fan
Sea foam
Any one try this in your fuel tank? Can you even use it with the dpf?
Old May 11, 2017 | 04:40 AM
Just Strokin's Avatar
Just Strokin
Did you check the Seafoam website to see if safe for diesels? And safe for dpf vehicles?
Old May 11, 2017 | 05:49 AM
capt caper's Avatar
capt caper
I wouldn't.... smells strong of alcohol,etc. Power Service is great.... fixed my furnace as well.
Old May 11, 2017 | 10:57 AM
donovan's Avatar
donovan
STOP
Do not use seafoam in any modern diesel. If you do you are looking at HUGE repair bill. Between 11-13k for the repair.
Now saying that what are you trying to do with the seafoam?
Old May 11, 2017 | 12:22 PM
1911fan's Avatar
1911fan
Nothing i just have some laying around. I hadnt even read the label. Im lazy i figured instead of getting dressed and going out to the shop id just ask.
Old May 11, 2017 | 02:00 PM
bayou barataria's Avatar
bayou barataria
I think it is alcohol based as well, wouldn't do it.
Old May 11, 2017 | 10:06 PM
BII Plow Truck's Avatar
BII Plow Truck
I know it's not good for older rotary pump type injection due to the isopropyl alcohol removes the lubrication for the mechanical pump, but modern electronic diesel injection there's no issue. Sea foam has been around since the 1940s and is awesome stuff and a very trusted brand. What they say on the can is 100% accurate.
Old May 12, 2017 | 08:48 AM
Pocket's Avatar
Pocket
Modern common rail diesels are sensitive to what is in the fuel. Remove a significant amount of lubricity, get water past the separator, insert any other fuel-related issue.... and it's easy to damage the high pressure fuel pump, injectors, and more. Repairs get very costly.
Owner's manuals for the Big 3 don't even necessitate the use of fuel additives, but if you do, Ford/Ram/GM are VERY specific about what to use. Ford insists on using PM22 or equivalent, which is basically a lubricity agent along with cetane boost. Anything else (high alcohol content, anything to do with cleaning agents or anything to do with emulsifying/demulsifying water) stay far far away from. They make these recommendations because they know that damage can occur from using the wrong types of additives.
vochy
Jan 21, 2018 11:33 AM
JaySVX
Nov 22, 2008 09:48 AM
GreatWhite
Mar 6, 2005 01:19 AM
Bruinzfan
Jan 28, 2005 03:30 AM
Dieselman929
Feb 14, 2004 09:30 AM
