Fuel additives During 6.7L Breakin - Ford Truck Enthusiasts Forums
2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Old 01-18-2018, 10:49 AM
vochy vochy is offline
vochy is starting off with a positive reputation.
Diesel experts, should you use a fuel additive like Opti-lube or Power Service during the first 1000 mile break-in period on a 2017 6.7L?
Old 01-18-2018, 11:00 AM
Shoester Shoester is offline
Shoester is starting off with a positive reputation.
I think I recall seeing in the manual a statement indicating that no fuel additives should be used during engine break-in.
Old 01-18-2018, 01:38 PM
DeputyDiesel DeputyDiesel is online now
DeputyDiesel is starting off with a positive reputation.
I used power service every other tank for the first couple thousand then changed to Ford PM22 every fill up now. I run it to 1/4 tank which puts about 20 gallons of new diesel in. So I bought some 4 OZ bottles and fill them with 3ozís of PM22. I believe I did my math right.
Old 01-18-2018, 02:18 PM
Robb81 Robb81 is offline
Robb81 is starting off with a positive reputation.
The only time you NEED a diesel additive is when temps are low enough to gel the fuel.
If you WANT an additive that is another topic.
Old 01-18-2018, 04:39 PM
roadpilot roadpilot is offline
roadpilot is gaining momentum as a positive member of FTE.
Quote:
I did and I would. Cetane booster year round and anti-gel in the COLD winter months. The cetane booster is my preference and anti-gel is just smart.
Quote:
I'd be curious to know if this is accurate. Got a page number?
Quote:
I used PowerService products until someone schooled me on emulsifiers vs. demulsifers in an HPCR (high pressure common rail) fuel system like our PowerStroke. I quickly switched to Motorcraft PM22 and PM23.
Quote:
Not accurate. A cetane booster is warranted if the cetane level in the fuel is lower than what the engine is designed to run at. That has been discussed ad nauseam here on the forums.
Old 01-19-2018, 06:51 AM
Thanks for the input so far guys. I read the owners manual and if I remember correctly the verbiage is something like: fuel additives are not necessary, however if they are used you should use the motorcraft additives or a product that meets there equivalent specs. That is kinda vague to me and didn't help with the break in question. On one hand a fuel lubricant seems like a great idea during break-in to prevent initial damage, on the other hand maybe these components need to "break-in" without the additional lube for proper longevity.
In the end I just want to do what is best for this truck to make it last as long as possible.
Old 01-19-2018, 08:34 AM
Redrockerstl55's Avatar
Redrockerstl55 Redrockerstl55 is offline
Redrockerstl55 is gaining momentum as a positive member of FTE.
The correct fuel additives can only help imo.
Don’t use the kind like Power service or you will have problems...they make it nearly impossible for the fuel separator to remove water from the fuel.
I only use AMSoil or OptiLube which both separate any water from the fuel making it easier to keep water out of the fuel system.
Ford products work like amsoil and optilube.
Many of us buy trucks in the winter with extreme cold temps and using fuel additives is a must from the first tank.
Old 01-19-2018, 09:52 AM
Pocket Pocket is offline
Pocket has a superb reputationPocket has a superb reputationPocket has a superb reputationPocket has a superb reputationPocket has a superb reputationPocket has a superb reputationPocket has a superb reputationPocket has a superb reputationPocket has a superb reputationPocket has a superb reputationPocket has a superb reputation
Quote:
This is a myth. There is no such fuel additive in existence that improves the function of the fuel/water separator.
Ford only recommends their additives or equivalent. Ford additives no NOT emulsify or demulsify water, and Ford does not recommend using any products that do.
As for the OP's question, if you use Ford additives or equivalent, you'll be just fine even on a new engine. Any other additive that emulsifies/demulsifies water, or has cleaning agents such as high levels of alcohol.... steer clear and don't use... ever.
Old 01-19-2018, 09:55 AM
Really??? Thatís news to me.
Old 01-19-2018, 10:24 AM
Quote:
But there are fuel additives that decrease the performance of the fuel/water separator.
You NEVER want to PROMOTE passing water, especially in a HPCR fuel system. Anything with an emulsifier contributes to doing just that, including the PowerService products.
Using additives that promote emulsification cause the water molecules suspended in the fuel to separate, making them small enough to pass the fuel/water separator filter. Additives with demulsifiers do the opposite, and the filter can do it's job.
Everything I've ever read claims that PM22 promotes demulsification.
Old 01-19-2018, 11:38 AM
Quote:
Ford doesn't promote emulsification or demulsification products. And I've never seen any Ford published literature or spec sheets on PM22 that would promote demulsification.
But I have seen numerous warnings in Ford publications and tech articles that specifically warn against using the wrong fuel additives. They state emulsification products and alcohol based products in particular, but they don't promote and/or warn about demulsification products. Ford is actually quite silent about demulsification.
So if they don't promote it and don't warn against it, I'm of the opinion that it's best not pursued as a viable option for additives in these trucks. In fact, my opinion is that demulsification is absolutely useless, is a marketing tool, and that in very extreme conditions can possibly contribute to water contamination problems.
Besides, the w/s works just fine. Diesel fuel naturally suspends a small amount of water, and the w/s is designed to handle that with no problem. The issue is fuel that is unnaturally heavy in water, but no amount of additives will help with that. With fuel that has a lot of extra water, the w/s will do it's job until it's full of water, then throw a light on the dash. At that point the driver had better stop immediately. Demulsifiers won't stop the w/s from filling up in those cases, or passing water to the engine if the driver continues to ignore the dash warning. Hence why I believe demulsifiers are completely useless and simply a marketing tool.
Old 01-19-2018, 01:47 PM
wfedwar wfedwar is offline
wfedwar is gaining momentum as a positive member of FTE.
All I've seen from Ford is to not use alcohol-based additives. That's all my manual says. Nothing about emulsifiers, demulsifiers, etc.
Old 01-19-2018, 02:38 PM
Painted Horse's Avatar
Painted Horse Painted Horse is online now
Painted Horse has a brilliant futurePainted Horse has a brilliant futurePainted Horse has a brilliant futurePainted Horse has a brilliant futurePainted Horse has a brilliant futurePainted Horse has a brilliant futurePainted Horse has a brilliant futurePainted Horse has a brilliant futurePainted Horse has a brilliant futurePainted Horse has a brilliant futurePainted Horse has a brilliant future
Decide why you think you need an additive. The choose an additive that solves that problem.
If you are in cold climate at a Anti-Gel
If you buying diesel that is low in Cetane, Then add a Cetane Improver
If you about lubricating the injectors and Fuel Pump, Then add something that boost Lubricity.
The bare minimum cetane in the US is usually 40. If I remember correctly, The manual says we should use 45 Cetane fuel. So I add an Cetane boost. If you live in an area that has premium diesel or where 45 cetane is normal., No additive needed.
Some of us lived thru the early days of 6.7L when there were rumors of HPFP failures. So some of us add Lubricating additives to make sure to protect that. Probably not needed. But old habits die hard.
Old 01-19-2018, 03:24 PM
Quote:
In the Ford Workshop Manual that dealers access, there is a GSB called "Diesel Fuel System Service Tips". It's a guide for dealer technicians to properly diagnose fuel contamination issues.
Below are screen shots of the latest version where Ford repeatedly talks about dispersment/emulsifiers. They mention it quite a few times in a 20 page diagnostic guide. This is just FYI for those following this thread.
Old 01-21-2018, 12:25 PM
Thanks. Confirms what I've read elsewhere.
First Engine Break-in. Suggestions? Aaron-71 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 25 01-24-2018 11:11 PM
Consequences of Towing before recommended Diesel Break-In Period KeysMako192 2017+ Super Duty 28 09-06-2017 12:11 AM
2017 6.7 PSD Break-in Thoughts? Bugged 2017+ Super Duty 9 07-20-2017 11:14 AM
Picking Up New F-250 Ranch King in 2 Days ToUtahNow 2017+ Super Duty 9 05-10-2017 09:08 AM
2000 miles on 17 6.7 invstr55 2017+ Super Duty 8 09-28-2016 02:30 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
