Well decided I’d definitely upgrade line sizes and was looking the Sd lines and bypass I can get brand new for 100 bucks total so probably the way I’ll go there along with im gonna get a autometer temp guage and hd2 tugger kit for time being also plan on getting a bts valve body in the future but not right now pretty much running truck stock for now since I got it fixed so honestly dont think I’ll brake it any time soon so we will see I’ll keep you guys posted
Well guys I finally just about have everything to complete this swap bought a new 4r100 pan with drain plug got a filter and good pan gasket online picked up a new torque converter to pump seal got a AutoMeter trans temp guage for my guage pod had a empty slot and pretty much have everything except lines and hose for trans cooler and fluid which I’m gonna order from ford new through my family’s buisness here soon but in the mean time I’m gonna start swapping small stuff over such as shifter tube and install trans cooler and I’ll probably install my 6.0 intercooler at same time and just cap lines till I get trans in I plan on starting after the New Years I’ll post pics as I get stuff accomplished any tips on installing a 6.0 intercooler and 6.0 trans cooler together thanks in advance guys
I honestly don’t know much about the converter other than it’s definitely not stock I’m gonna run it for now but I have full attentions of buy a triple disk once funds allow that way I know what I have in it exactly I’m I’m definitely ready to get the swap done as the trans I put in my truck to get me buy till I could swap because I traded good trans pops out of 4th which is rather annoying still looking for tips on intalling 6.0 trans cooler and 6.0 intercooler as well
Well thought I’d update you guys on my progress which is slow but surely coming along I’ve been sandblasting and painting parts for the swap along with other parts I plan on installing soon here’s what I’ve got done so far
Well it’s been a while but some other bills came up but I ordered motorcraft trans fluid and the superduty lines and bypass all I’ve got left is to figure out if I’m gonna run an fittings and pushlock on other fittings or if I’m gonna run regular hose and clamps i used all an And pushloc on a buddies fuel system we built and I really liked how simple it is to use and how clean it looks so may be the route I go but I’ll post pics of new parts when they come in tomorrow
Well stuff came in from our ford parts supplier got motorcraft atf for little over 4$ a quart threw them hopefully I can get my last few parts ordered soon
You're not going to put MERCON LV in your trans, are you? I predict a VERY short life for that trans on MERCON LV. That fluid will destroy it. You need MERCON V.
When I called and ordered parts I said trans fluid for my year truck maybe they sent wrong stuff I thought they changed it to be compatible or something guess that’s what I get for waiting 6-7 months to do this project lol
MERCON V was changed to be compatible with transmissions that originally used MERCON. That includes the E4OD and 4R100. MERCON LV is NOT compatible with those transmissions.
I had been wondering. Odd thing is I couldn't find Mercon V awhile back...only the LV stuff. I had to order it, which made no sense to me.
