battery terminal clamp
Old Apr 24, 2017 | 07:22 AM
kylant's Avatar
kylant
Does anyone know of a source for the battery terminal clamps other than the dealer?
I am talking about the the little “L” bracket clamp that tightens the terminal down to the post.
I noticed yesterday the negative one on my passenger side battery was broken, therefore not clamping the terminal tight to the post.
I have never touched this, so I know I did not over tighten it
Old Apr 24, 2017 | 10:46 AM
EpicCowlick's Avatar
EpicCowlick
It is a unique little setup Ford has created. I saw it for the first time while installing airbags and still wonder what the value is in being so fancy. Regardless, I'm sure it works well (assuming it doesn't break like yours) and there's a reason for the design.
Here's a link to a replacement on Amazon:
https://www.amazon.com/Ford-BATTERY-CLAMP-BOLT-BT4Z-14450-AA/dp/B008Y80GZE/ref=sr_1_1?ie=UTF8&qid=1493048628&sr=8-1&keywords=ford+battery+clamp https://www.amazon.com/Ford-BATTERY-CLAMP-BOLT-BT4Z-14450-AA/dp/B008Y80GZE/ref=sr_1_1?ie=UTF8&qid=1493048628&sr=8-1&keywords=ford+battery+clamp
Old Apr 24, 2017 | 11:00 AM
AMXDREAMER's Avatar
AMXDREAMER
As cheap as this sounds I would tell the dealer to replace it under warranty. 3 years bumper to bumper warranty is there for a reason. It's so I don't have to spend 35 bucks on a battery clamp and then do the work changing it over.
Old Apr 24, 2017 | 12:17 PM
69cj's Avatar
69cj
Ditto ^^^^^^
Old Apr 24, 2017 | 10:07 PM
kylant's Avatar
kylant
i have seen that clamp.
all i need is the clamping “L” bracket wedge bolt thing.
I don’t know if it is available separately. I really don’t want the service department to replace the whole terminal. I will see what parts says tomorrow. I may just bite the bullet and pay $15 for the $1 part
Old Apr 24, 2017 | 11:53 PM
AMXDREAMER's Avatar
AMXDREAMER
Get them to order it in and just to change the bracket.
Old Apr 25, 2017 | 03:18 PM
kylant's Avatar
kylant
went by the dealer. not only is the bolt not available, neither is the terminal for a SD.
They would have to replace the whole cable. I don’t have time for service to do that, nor do I want them removing that whole cable (it is not just a simple one).
I opted to buy a negative terminal that has that clamp bolt. I will just rob the bolt.
Unfortunately the dealer did not have it in stock. won’t be able to get it until friday.
Old Apr 25, 2017 | 03:29 PM
Johnpsz's Avatar
Johnpsz
I hope it works out for you and that it solves your issues, keep us posted.
Old Apr 25, 2017 | 04:10 PM
USSenator's Avatar
USSenator
The next time it breaks and you do have time for warranty service, they dealer will say "that is an aftermarket part. It is not our responsibility".
Old Apr 25, 2017 | 05:38 PM
mhoefer's Avatar
mhoefer
Keep the old part and make em replace it next time its in for service of any kind. I keep a list.....
tryingaford
6.7L Power Stroke Diesel
18
Mar 13, 2020 03:39 PM
HouseMouse
Oct 16, 2017 11:16 AM
KelVarnson
Feb 21, 2012 10:11 AM
medic92
2004 - 2008 F150
Feb 6, 2008 08:57 PM
tealboy1
1997 - 2003 F150
Oct 18, 2005 05:49 AM
