Battery Tie-Down Corrosion....
Old Oct 16, 2017 | 10:38 AM
HouseMouse's Avatar
HouseMouse
Just did an under-hood Engine check after a long trip. Found some or the usual battery corrosion on the battery Tie-Down strap across the top of the battery. The Positive and the Negative terminals are clear of corrosion. There is some Battery Acid Vapors(?) across the top and under the Tie-Down. Guessing that is what is causing the corrosion. Question: Is there a way to prevent this corrosion? or, is it a lost cause.
Old Oct 16, 2017 | 11:16 AM
jaxf250's Avatar
jaxf250
Not sure, but maybe Ford got a bad batch of batteries at one point - see the video I linked to here in this post earlier: https://www.ford-trucks.com/forums/1...l#post17517550
After listening to this tech's comments while recording it, my best guess, the dealer replaced both (possibly?) under warranty? ymmv
Avanti
Escape & Escape Hybrid
Dec 21, 2019 12:28 PM
coollooking96F350
Aug 16, 2011 08:11 AM
hojolabo
General Automotive Discussion
Oct 21, 2008 07:13 PM
BigDog83
Mar 29, 2008 09:29 AM
triton_2002
1997 - 2003 F150
Sep 21, 2003 01:44 AM
