Hot No Start
Old Apr 17, 2017 | 09:58 AM
Dcook175's Avatar
Dcook175
Hot No Start
I have a 2006 F350 6.0L. That is Having trouble starting after it is warmed up. Ive been told multiple things it could be but the one ive been told the most is the Stand pipe or dummy plug in the oil rail having a small leak. Is this correct? or is there something else i need to Check??
Old Apr 17, 2017 | 12:34 PM
redford's Avatar
redford
FTE Leadership Emeritus
Moved to 6.0L PSD forum.
Old Apr 17, 2017 | 12:57 PM
Benchwrench's Avatar
Benchwrench
a OEM STC fitting will have the same symptoms.
Old Apr 17, 2017 | 01:01 PM
Turd-250's Avatar
Turd-250
ideally, having a monitor of some type to view a few engine parameters would help you to be more sure that it's indeed standpipes, dummies, or STC ^^^. you'd be looking at the ICP and IPR values to start off with... but yeah, you're probably on the right path!
Old Apr 18, 2017 | 11:04 PM
stanley6.0's Avatar
stanley6.0
There is most likely a leak in the High Pressure Oil System. Check the STC fitting, the HPOP, standpipes and dummy plugs, maybe a bad injector?
Old Apr 19, 2017 | 07:06 AM
bismic's Avatar
bismic
There is a no-start troubleshooting thread in our Tech Folder.
Old Apr 19, 2017 | 07:09 AM
navistarnut's Avatar
navistarnut
Not likely the HPOP on a later build.
One thing that seems to be skimmed over here often are the nipple cups/o-rings and top injector seals.
Not as common but a leak point nonetheless that does go bad, which is why at the end of the day nine times out of ten you have to air test.
Old Apr 19, 2017 | 12:24 PM
Tideman's Avatar
Tideman
I agree, air test before replacing anything.
Old Apr 20, 2017 | 02:00 PM
ithaca1230's Avatar
ithaca1230
I was having same issue recently. Ended up being the ICP sensor.
Skraztastik
Mar 3, 2015 10:28 AM
nascarandy
Dec 24, 2011 07:17 AM
ezf250
Dec 29, 2009 03:17 PM
bronco351
Mar 23, 2008 08:57 PM
f250grs
Oct 24, 2006 10:49 AM
