Push to Start
Old Mar 31, 2017 | 09:07 PM
saskowner's Avatar
saskowner
Push to Start
I don't have my truck yet but I have been reading the manual online and can't find an answer to my question. When starting the truck in cold weather what is the process using the push to start regarding the glow plugs? If you push and let go does it automatically warm the glow plugs and then crank the engine?
Gary
Old Mar 31, 2017 | 09:09 PM
bridge's Avatar
bridge
Sick 'n Tired
Yes. A message in the Info Center says "Starting Engine" and about 1-2 seconds later it starts.
Old Mar 31, 2017 | 09:29 PM
BII Plow Truck's Avatar
BII Plow Truck
I think he's asking if you push and let go, or push and hold to start.
Old Mar 31, 2017 | 09:35 PM
Litre's Avatar
Litre
You just hit the button. The truck handles the glow plug delay. When the truck is warm, it'll crank immediately. If it's cold, there'll be a couple second delay
Old Mar 31, 2017 | 09:42 PM
mhoefer's Avatar
mhoefer
Delay to start between warm and cold days is very limited. Yes, you push the button or remote start and the system does the rest. It's actually almost imperceptible between -5 to -25 C outside temp on a cold soak over night. Remember this is not your older glow plugs, these get instantly hot, and it cranks over and starts and very fast in comparison to my 2005 6.0 diesel. Remember also, your not cranking a high pressure oil pump to fire HEUI injectors. Instead, high pressure fuel pump, and injectors fire instantly.
Old Mar 31, 2017 | 09:49 PM
saskowner's Avatar
saskowner
Thanks very much for the replies. I wonder how I was missing that information in the manual. Glad to hear that it handles the glow plugs so seamlessly.
Gary
Old Mar 31, 2017 | 10:23 PM
HRTKD's Avatar
HRTKD
Sometimes what is obvious to the guys writing the manuals isn't as obvious to those people reading the manuals.
Old Mar 31, 2017 | 10:53 PM
saskowner's Avatar
saskowner
Truer words were never spoken. In my case the problem is magnified since I don't have the truck in front of me to try things out on.
Gary
Old Mar 31, 2017 | 11:41 PM
HRTKD's Avatar
HRTKD
I understand. I also started reading the manuals before I had my truck.
Old Apr 1, 2017 | 08:50 AM
Frantz's Avatar
Frantz
When you're entrenched in product on a daily basis you forget some people haven't yet been exposed to the technology you've had in the trucks for 5 years. Push to start is nice. I wish they used the same for the key, and I don't know why they don't. Ford keys don't need held to start, they'll just crank until they fire (or 10 seconds goes by). The diesel should run it's start sequence, but as of right now if you put the key in, it'll start cranking without warming up the glow plugs first.
ScrapeApe
Jul 27, 2019 08:18 AM
lts
May 1, 2017 10:29 AM
Frank250Tank
Jan 10, 2017 10:00 AM
ALedbetter1
15
Apr 8, 2013 10:22 PM
cHiLi 11
General Diesel Discussion
May 16, 2007 08:50 AM
