Glow Plugs Delay
Old Apr 30, 2017 | 09:13 PM
lts's Avatar
lts
Glow Plugs Delay
Got my truck back from the local dealership recently after having the transmission replaced (another victim of the early build cooling line issue).
I know they updated the PCM, TCM etc. while it was in the shop since it was an early build (late August). I confirmed with them that they did in fact update the modules.
But now there is no delay when I start the truck. Before this work was done it would have a one or two second delay after hitting the start button (or initiating a remote start). I'm in TX & LA most of the time so it's not really cold, but there zero delay now. I mentioned this to the service manager shortly after getting the truck back but he didn't seem to think it was an issue.
I'm no diesel expert, but from what I've learned over the years, it's not good for the engine to crank if the combustion chamber isn't properly heated. I also know the glow plugs have gotten faster over the years. Still concerned about this immediate start thing.
Anyone else experience this after having the PCM updated?
Thanks,
Gentry
Old Apr 30, 2017 | 10:17 PM
347Flatty's Avatar
347Flatty
I have a truck built recently but I don't have the push button start. When I turn the key on, the glow plug symbol will appear for a second or two and then I start it. With that said, I can just as easy put the key in and start all in one motion without any starting issue. It starts right up. Honestly I'm not sure if it matters much to wait on these new diesels to wait?
Old Apr 30, 2017 | 10:22 PM
Painted Horse's Avatar
Painted Horse
The glow plugs on the 6.7 go from ambient temp to 1200° in 2 seconds. So you don't need a long wait like the 7.3L engines. If the engine is already warm, there is almost no wait
Old Apr 30, 2017 | 10:34 PM
347Flatty's Avatar
347Flatty
Is there any down side to starting immediately since it doesn't seem to matter? I'm used to the 7.3 and we all know how that worked
Old Apr 30, 2017 | 10:38 PM
Painted Horse
Once my truck has been started in the morning, the rest of the day, I pretty much jump in and turn the key. My 2011 ran 150,000 with no problems and my 2015 is almost to 70k with no problems. I've yet to replace a glow plug
Old Apr 30, 2017 | 11:20 PM
BII Plow Truck's Avatar
BII Plow Truck
Modern day diesels don't use the glow plugs to heat the combustion chamber if coolant temperature is above 34*F. (Not sure the exact degrees on a Ford). Basically above that temp it's the compression of the cylinder makes the heat required to start, and the light on the dash is just to tell you the light is working.
Old May 1, 2017 | 01:16 AM
AK_SuperDuty's Avatar
AK_SuperDuty
With the push button start at temperatures around -10 this winter, truck not plugged in or run for at least 12 hours, my truck starts within 1-1.5 seconds of pushing the button. It's never taken longer than that.
Old May 1, 2017 | 05:34 AM
Adam R's Avatar
Adam R
Just an FYI, but the glow plugs do nothing to "pre-heat" the combustion chamber in a modern DI engine. A tiny red hot glow plug transfers effectively zero heat to the nearly 1 liter volume of space in a cylinder. They are there to ignite the fuel that is sprayed on the red hot tip of the plug. Modern glow plugs heat up very quickly whereas older ones take 6-10 seconds to become cherry red. That is why you used to have to wait in the "olden days". Also, anytime the engine is above luke warm, glow plugs are unnecessary. I had an old IDI diesel with a manual glow plug controller. So long as the engine had some heat in it, I never bothered with the glow plugs. The first firing of the day however required the plugs, especially if it was below 50 degrees.
Adam
Old May 1, 2017 | 10:00 AM
Merlin053's Avatar
Merlin053
My truck has no delay at all after you press the start button and it fires up right away. Much different then my 09!
Old May 1, 2017 | 10:29 AM
lts's Avatar
lts
Thanks you guys for the great info.
Makes me feel much better about the zero delay.
ALedbetter1
15
Apr 8, 2013 10:22 PM
Militaryman4455
May 4, 2011 08:00 AM
FordTE
Jan 11, 2010 06:54 PM
cHiLi 11
General Diesel Discussion
May 16, 2007 08:50 AM
deckguy
Nov 20, 2005 01:55 PM
