Kubota's Modifications thread, w/ chit chat
You say you have 37x12.5 RT's on 20x9 +18 offset, this is the EXACT setup I want to use with a 2.5" carli front level. However I am very afraid it will rub on the radius arms and swaybar. I started a thread on this and had two people say they have this setup and theirs rubs:
https://www.ford-trucks.com/forums/1...ffset-rub.html
Are you 100% sure you have no rubbing anywhere? I am trying to gain confidence on the +18 offset, as I want to avoid 0mm offset as I think it sticks out a bit too much for me.
Your help is appreciated!!
I have the exact same wheels as Kubota. Same size and offset. I was running the same 37 toyo RT. I had rubbing. you can see Kubotas rub. I had the same. I rubbed more on the driver side, especially the sway bar.
I think the rub was more due to the sway bar drops moving the bend of the bar to a different location. and the fact the axle was still pushed to the passenger side. I have a full Carli 2.5" system with the Carli track bar adjusted as short as possible. the axle is still off center about 1/2-3/4" to the passenger side
when I had the Readylift track bar relocation bracket with the stock track bar, the axle was perfectly centered.
Took these for you, ive put about 3000 miles on the truck with these tires. Looks like radius arms may have been touched a time or two? not really sure. I do know i have never felt anything rub. The ford mud flaps on the other hand is a different story, Its taken quite a bit of tirimming to keep the tires off of them. I wanted to keep them to help keep road spray under control.
Thanks for the further input! I didn't realize that the Carli trackbar was not centering the axle perfectly like the Readylift relocation bracket does... I wonder if Carli knows this and is working to correct it.
So I am guessing NOT using the sway bar drop brackets helps against rubbing as Kubota's looks tucked up tight, and Kylant had worse rub with his dropped down. What does dropping the sway bar down fix? Risks to not using it?
Getting the axle centered also has to help against rub, I will need to ask Carli if they are working to fix this issue.
Thanks to the both of you!
Josh
Kylant,
Josh
I ran my sway bar with and without the sway bar drops. I noticed no difference in truck performance. The rub was definitely more with the drops in place. I figured Carli had them for a reason, so I reinstalled them
Kylant,
Josh
I consider rubbing like what i get on the radius arms of my 78 with 37's or before i trimmed the crash bars on my wife's f150.
Axle center would affect the sway bar rub, should have minal effect on radius arms.
My axle is within 1/4" of being centered with the bds bracket, best i can tell measuring by myself. I dont see the need for swap bar drops with the 2", i didnt forsee a problem with binding of the sway bar when installing the spacers just playing with suspension travel.
Feels like the torque is finally being utilized now. Shift pattern is similar to stock, Keeps you in high gear under low load situations, firm smooth shifts but not hard, i could stand them to be a little firmer, torque convertor is quicker to lockup in the lower gears, Im not sure but i believe lockup in 3rd and maybe second, i will pay more attention. Before normal driving I only noticed lockup late in 4th gear, even pulling a hill accelerating, which was extremely frustrating. Also there used to be an annoying lag, say coming down a hilll with exhaust brake on at ~40 mph, start back into it with minimal throttle and she would just hang there at 2500 rpm and i would be cussing shift you @!#$%. That seems to be improved.
Overall, crisp firm shifts, more efficient shift pattern and more tq convertor lockup. I will confirm if there is lockup in 2nd or 3rd now in normal driving.
Its too bad you cant tune the trans on a stock truck without tuning engine, this would be a huge improvement.
If it ever stops raining im going to set her on kill and give it a run, now that ive got some extra line pressure to hold the power
Kubota next time you get a chance, could you take a photo from the front/back or even both from a decent distance back to get a good look at how your tires look? Like even further back than this so you can see both tires at the same time and how they sit relative to the fenders.
http://www.addictivedesertdesigns.co...uty-bumper.jpg
