Need some 4r100 help
Old Mar 17, 2017 | 06:56 PM
texbigred1's Avatar
texbigred1
Started having problems with my 02 f250 7.3l. It would run and not move like it stuck in third gear. So I read the codes had 4 differnt trans codes 755, 743,1754 and 1747 also had an idm code 1316. Called the transmission shop he said check the pigtail on the solenoids. I did and the wires were messed up. So I put a a new pigtail on today. Now the truck will drive. Has hard shifts and od light still flashes. Pulled the codes again. And same codes. I checked the fuses replaced ones that might have something to do with trans. I'm at a loss here. Is there anything goes else that could do this? Am I missing something? I can't really afford to take it to a shop right now. Hoping to get it fixed. Any help would be appreciated. Btw the new plug was a little differnt. The factory one had this on the 2 red wires and this is what the plug looked like
Old Mar 17, 2017 | 10:22 PM
jk080's Avatar
jk080
Transmission Rebuilder
Did you clear the codes after the repair and they all came back?
Did your pigtail come with instructions?
What is the differences in the connector you are referring too, does it fit well on the solenoid block?
Name:  4R100 wiring connector.JPG
Old Mar 17, 2017 | 10:43 PM
texbigred1's Avatar
texbigred1
The two power wires were heat shrinked together not sure why. The new harness the wires were seperate. As for clearing the codes. My scanner says no communication when I try. Is there another way to clear them? I did have the battery disconnected for an hour while I redid the wireing. Also did one wire at a time so I wouldn't mix anything up
Old Mar 17, 2017 | 11:11 PM
jk080's Avatar
jk080
The two power wires are illustrated in the wiring diagram above, they both get power from the central junction box, and going into pin cavities 1 and 12 on the connector, that's the way it comes from the factory.
If the scanner is showing no communication during the clearing process then the scanner did not clear any codes, try disconnecting the battery and touching the two cables together for a few minutes, sometimes this will clear things out.
Old Mar 18, 2017 | 07:15 AM
texbigred1's Avatar
texbigred1
I'll try that this am. I also visually checked the harness all the way back to the computer . No rub thrus
Old Mar 18, 2017 | 10:30 AM
texbigred1's Avatar
texbigred1
Ok cleared the codes now getting one trans code1746. May still have a bad wire. Have to check after the rain quits. Also had some cylinder codes p1272 1273 1724. High to low side open
Old Mar 18, 2017 | 06:03 PM
texbigred1's Avatar
texbigred1
Ok fixed the trans problem. Shifts great and no od light
Old Mar 18, 2017 | 07:24 PM
texbigred1's Avatar
texbigred1
Spoke too soon. Went to move my truck and the light came right back. Has the codes I started with now. Checked the fuses and connection all good. I do think get it
Old Apr 30, 2017 | 08:18 PM
texbigred1's Avatar
texbigred1
Well after running fine for over a month it's back at it. Stays in 3rd gear. Pulls all six codes again haven't had time to dig. But I'm thinking the power wire is dead again. Any one know if I can run a new red wire with out having any other problems. I'll cut the wire at the on and run new in a sleeve to the transmission and secure to old harness.
Old May 2, 2017 | 10:03 PM
texbigred1's Avatar
texbigred1
Ok. I pulled the plug and checked voltage had 12 volts going to both pins. Cleaned the connection. Pulled the kam fuse for a couple mins. Tired up no codes and would drive. Just don't understand. Only thing I can think of is it rained the day it messed up. Maybe water got in a connection? I'll drive it and see what happens
albacore26
13
Sep 8, 2012 10:21 PM
Jules3084
Jun 13, 2011 11:32 AM
onedangerouswookie
1997 - 2003 F150
Jun 5, 2004 10:45 PM
peter matthews
Jul 16, 2003 06:39 AM
