Equus 3145 problem
Old Apr 18, 2012 | 09:07 PM
albacore26's Avatar
albacore26
Equus 3145 problem
I just bought a 92 F250 7.5 and the MIL came on after changing the battery so I bought a Equus 3145 to get the codes and I'm not getting the reader to pull the codes. When I plug in the reader and press the test button I can hear relays and other things clicking but my reader is doing nothing but showing 000 not even having the triangle come up on the screen. I swear there is no corrosion on the connector wires and I've cleaned the contacts with a small screwdriver. Do I have a bad reader or has anyone run into this? I really don't want to send it back but may have to and just count the MIL flashes.
I don't know if it would make any difference but the truck is an early 92 (10/91)
Old Apr 18, 2012 | 09:57 PM
minnesotafisherman's Avatar
minnesotafisherman
I had the same problem when I bought that exact reader, Equus 3145. It would not work. No corrosion on wires, and I heard things powering up when I plugged it in and also got the zeros, same problems as you. I just returned the thing and had my local shop pull the codes for me for free.
Old Apr 18, 2012 | 11:47 PM
TexasGuy001's Avatar
TexasGuy001
I'm interested in finding out what caused that issue. I have one and it works fine on a few different trucks.
Old Apr 18, 2012 | 11:54 PM
Ddaybc's Avatar
Ddaybc
I bought the same tester and had to return it for the exact same reason. I tried two more but none of them would work reliably so finally returned the final one and got my money back. Now I just get the shop to pull the codes for me.
Equus 3145 made in China
Old Apr 19, 2012 | 12:04 AM
TexasGuy001
Mine is made in Taiwan. For quite some time this reader has been a favorite on this forum.
Old Apr 19, 2012 | 12:18 AM
Ddaybc's Avatar
Ddaybc
Texasguy001 I know the Equus 3145 has been a favorite on the forum. I bought mine after it was recommended to me from a few members. That's why it puzzles me that mine didn't work.
I didn't know any of the Equus testers were made anywhere else but China. All three of mine had a made in China stamp on them. Then again, I did buy them from Canadian Tire. Maybe I'll check them out at Lordco, they may get theirs from a different supplier.
Old Apr 19, 2012 | 01:12 AM
albacore26's Avatar
albacore26
I guess it makes me feel a little better knowing it wasn't just me or my truck in some way. I'd really prefer to use a code reader over the counting lights method so I'm thinking of trying another but from the sounds of it I need a place with a easy return policy, I don't expect Amazon to be a problem with this one though. For what it's worth this unit is made in Taiwan.
So far with only in town stop and go driving I've gotten 8 mpg and with gas prices at $4 I need this truck to be running as close to perfect as possible, I'd like to see at least 10 mpg but that might not be a reality.
Old Apr 19, 2012 | 10:27 PM
Conanski's Avatar
Conanski
You guys were connecting the the single STI wire to the code reader as well right?
Old Apr 19, 2012 | 10:41 PM
minnesotafisherman
Yep, I did. And it still didn't work. O'Reilly's free-to-use reader didn't work for me either.
pintoches's Avatar
pintoches
I have used my code reader on the 92 many times, others too, but it will not read my 89 mustang!
Old Apr 20, 2012 | 06:39 AM
subford's Avatar
subford
Does your MIL flash when you ground the STI wire and turn on the key?
Old Apr 20, 2012 | 08:04 AM
albacore26's Avatar
albacore26
STI was plugged in, when I tried without nothing was powering up.
Old Apr 26, 2012 | 01:02 AM
albacore26's Avatar
albacore26
I got my replacement in the mail the other day and it works fine other than a couple hash marks missing on the last digit that I can get back on with a gentle squeeze of the screen.
I've been doing some reading about code 41 tonight.
Old Sep 8, 2012 | 10:21 PM
gwtx2's Avatar
gwtx2
Make sure the test connector is correctly attached to the scanner. On my truck, it will connect right side up or upside down. If the latter, then I get the same symptoms you describe.
texbigred1
May 2, 2017 10:03 PM
Treytaw
Apr 19, 2013 06:23 AM
drivembig
Jan 13, 2010 06:49 PM
have3fords
Bronco II
Oct 25, 2007 02:30 PM
05SD
Sep 13, 2005 10:22 AM
